    Pi in a Sega Genesis USB Hub Build
    sega genesisgenesis usb hubbuildconsoleproject
    237 Posts 23 Posters 223.2k Views
      edmaul69 @cyperghost
      @cyperghost I guess i never looked and just assumed the pi zero had one. I guess for $5 it wasnt cost effective, plus if it blows up who cares?
        Stig
        @edmaul69 @cyperghost @obsidianspider Thank you all!
          cyperghost @edmaul69
          @edmaul69 Yes 5$ are not so expensive but I think if you use a stabilized power switch device there is no problem in blowing the Pie. Therefore I would never use an old power device (with coils inside). These transform an output voltage in depence to the input. I would suggest up to 5.5V the Pie is running fine (no guarentee!! ;).
          So the Pi0 is a special device .... with an overvoltage you kill it... independent from the way you power it.
          For the polyfused Raspberries you can kill them only via GPIO powering because the GPIOs aren't fused.
            @obsidianspider Hi, long time not seen. I hope you are fine....
            Did you remember as we talked about the volume change thing? I think I'm on a breakthrough.
            I was able to find a sliding switch with an integrated push button inside. So I'm able to set the switch in volume up or volume down position and by pushin the button I can give a signal to the wired GPIO to raise or lower volume.
            My first attempts were lazy work by polling the status of the GPIOs but that doesn't fit my imagination of a good implementation ... Interrupts are better.
              @cyperghost can you post a link to the switch? I would love to see a two way slide switch that returns to center
                @cyperghost yeah i have to agree with you. I was a little sarcastic about it blowing up. :) Low volt power supplies these days are pretty safe. Unless you plug them into your phone and your battery blows up. Lol
                  @edmaul69 said in Pi in a Sega Genesis USB Hub Build:
                  I do not know what you are talking about. Big companies do excellent quality control and test new devices for every situation in daily duty. You ca not imagine what that means if a new developed device does blow up in a critical situation .... Maybe on an aeroplane ;) Does this ever happenend?
                  SARCISTIC
                  Back to normal. The switch is called SLP-23-492T .... I just saw this in only one shop so I think it is not very common. But it is really made for the SEGA build.
                  Edit:
                  No it does not return to center. It is a combination if a sliding switch with 3 fixed positions in together with a push button function.
                  So you connect ground of push button and slider together and can so use it.
                  I found a small joystick button that works as you descriped but thats SMD tech and awful for soldering and mounting. Other switches are mich to big to fit.
                    mattacac
                    Hey all,
                    Two things - Shirtpunch guarantees all their orders, you get it, or you get a complete refund.
                    Second thing: they have a bundle on sale today for the USB hub, a NES USB controller, megaman bluetooth speaker, and a genesis tshirt for $19.99. https://www.shirtpunch.com/the-ultimate-retro-bundle
                    check it!
                    ![alt text](0_1487095240586_upload-67cf05d2-6d6d-4ed1-a6b1-626a40070ecf image url)
                      TFW you see your photos from this build showing up on eBay auctions :-/
                      What the heck?
                      πŸ“· @obsidianspider
                      • hansolo77H
                        hansolo77
                        That actually pisses me off.
                        Who's Scruffy Looking?
                          obsidianspider @hansolo77
                          @hansolo77 Me too. They are using those photos in a number of listings. I messaged the seller, but I'm not sure they'll take them down.
                          • hansolo77H
                            hansolo77
                            Maybe you need to contact eBay directly..
                            obsidianspiderO 2 Replies Last reply Reply Quote 0
                              @hansolo77 Ugh, the seller even says this in the description
                              You can see much more information on this process by searching Google for "retropie topic 6003" and it should be the top response
                              • hansolo77H
                                hansolo77
                                :( wow
                                  @hansolo77 It looks like their only mechanism is if I had a listing of my own that the other seller copied.
                                  Other stuff requires a DMCA notice, per their website, and ugh.
                                    @hansolo77 Yeah, the only thing I can really do is update the original post.
                                    Edit: Done. Boldly.
                                    mooseprM 1 Reply Last reply Reply Quote 0
                                    • mooseprM
                                      moosepr @obsidianspider
                                      @obsidianspider B*ds 😞
                                      Everyone is out to make a quick buck
                                      want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
                                        I'll say this, the seller responded first thing this morning, and did remove the photos, at least from the initial post. Hopefully they will also be removed from their other listings.
                                          There is some hope for the world. The seller removed my photos from all of their listings and was polite in their correspondence.
                                          I removed my note at the top of the original post.
