    Pi in a Sega Genesis USB Hub Build
    sega genesisgenesis usb hubbuildconsoleproject
    237 Posts 23 Posters 196.6k Views
    • E
      eulogy
      just wanted to thank obsidianspider for making this thread..as well as the contributors. i used this idea to make my own sega pi... i managed to fit a 40mm fan and an othermod.com shutoff circuit into mine and love it!
      thumbs down to the ebay lame using this thread to profit. least they could do is make it then sell it?!
      anyways i thought i was done with mine...but manage to keep making little tweaks to my setup.
      special thanks to othermod.com for his help with his circuit!! support this guy's hard work!
      "specs"
      -Raspberry pi 3b
      -Overclocked CPU 1375mhz/ GPU 500mhz
      -Retro Pie 4.1
      -Sega Genesis and Turbo Grafx logo conversions
      -Removed splash screen and rainbow on boot screen
      -Custom "now loading" image when loading core
      -Eazy Hax's - External USB Drive expansion script
      -All emulators optimized for display size and resolution
      -Manually Edited, personally compiled Romset, including Universal XML scraped art (9k+ - no duplicates within individual consoles)
      -Sega Genesis USB hub converted to case (original wire replaced with 22awg)
      -Lower intake vents and upper exhaust vent/mesh grill
      -40mm fan
      -Heatsinks/Arctic Silver thermal paste
      -Power button and - otherMod.com - shutdown circuit
      -Functional power LED and front USB hubs (tied to raspberry)
      -Removed Micro USB
      -Playstation 3 Bluetooth Wireless Controller
      0_1488425044508_20170218_203050.jpg 0_1488425070958_20170218_190116.jpg0_1488426105378_20170218_190356.jpg
      adamspcA edmaul69E FlyingTomahawkF 3 Replies Last reply Reply Quote 2
      • adamspcA
        adamspc @eulogy
        @eulogy said in Pi in a Sega Genesis USB Hub Build:
        Thanks for the shout out. I love seeing my boards in these builds.
        https://www.othermod.com
          edmaul69 @eulogy
          @eulogy i love the grill. I would love to know your method you used to cut it /file it?
          • E
            eulogy @edmaul69
            @edmaul69 i used a dremel with a cutoff wheel through the backside..cut a rough hole then kept carefully shaving it down. then used some small cheap files from harbor freight, which for the price are pretty good. ive used them on metal, and they have different shapes in the pack. finished it up with some 1000 and 2000 grit sandpaper.
              Koji Kenshiro
              @eulogy
              I'm thinking of making one of these as a fun little project and have a quick question? Would this power supply be a good one to get for this? https://www.amazon.com/Sabrent-100V-240V-Adapter-Support-PS-5V25/dp/B00MRFR1XA/ref=nav_ya_signin?ie=UTF8&qid=1488568451&sr=8-16&keywords=5v+2.5a+usb+power+supply&
              Just thought I'd ask before going and buying everything for the build? Thank you and have a good day! :)
                obsidianspider @Koji Kenshiro
                @Koji-Kenshiro That doesn't appear to have a Micro USB plug on the end, so unless you're doing something different to interface with power, that's not going to work.
                  Koji Kenshiro
                  @obsidianspider @eulogy @adamspc
                  I'm thinking of interfacing it with the Improved On/Off Board that eulogy used for the power switch.
                  • E
                    eulogy
                    that should work as ling as u count on soldering it...raspberry pi 3 need 5v 2.5amp power supply. the one u linked to looks like my "viaboot" i have...which i believe is just a chinese ebay type thing. id just stray away grom the power supplies that have inline power switch built in.
                      Koji Kenshiro
                      @eulogy
                      Would a power supply like this one be better than the other one I linked since it's primarily designed for the Pi? It also has a nice length to the cord also, which will help when hooking it up. I'm planning on soldering it the the Pi via the test pads underneath the micro USB port.
                        Koji Kenshiro
                        @eulogy
                        https://www.amazon.com/gp/product/B01K7EF2XS/ref=ox_sc_sfl_title_1?ie=UTF8&psc=1&smid=A3DV0CVGW4L6E5
                        • E
                          eulogy
                          as long as its 5v 2.5 amp id say its fine..both u linked might even be the same.
                            Koji Kenshiro
                            @eulogy
                            I think the second one that I linked has a much longer cord than the first one does. I'm thinking of using the second one for that fact and that it is advertised to work with the Pi.
                            • E
                              eulogy @Koji Kenshiro
                              @Koji-Kenshiro the block itself i think is similar...id go longer cord myself
                                Koji Kenshiro
                                @eulogy @obsidianspider @adamspc
                                That's the one I'm leaning towards as well for the same reason. If I have any more questions, I'll be sure to ask. Thank you all for being patient with me. Have a good day. :)
                                  Today I decided to upgrade the internal storage of the Genesis Pi.
                                  Best Buy had 256GB Sandisk USB drives on sale for $65. I got two. One for the Genesis hub and another for my Super Famicom.
                                  They're small, but not as small as the Sandisk Ultra Fit drives that are known to get so hot you can't even touch them. They're also well-reviewed.
                                  Unfortunately, while small, the drive was a bit too big to fit inside.
                                  No worries, I knew that the plastic case had a lot of "extra" to it, so I took the plastic off and was left with a much smaller device.
                                  You can't see it quite from this angle, but the edge of the PCB is just about flush with the edge of the case when plugged in. That said, the case was a bit in the way, and was putting pressure on the board.
                                  Using a file I made a notch for the PCB and its LED. I didn't want the case to put pressure on the board when it was closed.
                                  It fit well, but after screwing things shut and powering up the Pi, the blue light from the LED was pretty annoying.
                                  To remedy the situation I put a piece of black tape over the LED, and also to help the board blend in with the case, I colored the edge with a black Sharpie.
                                  Now when it's powered up, if you aren't looking for it, you really can't see that the drive PCB is there.
                                  I followed the instructions on the documentation site for how to set up the drive, and I found that while the directory structure and default BIOS files were copied over, the ROMs were not, and the contents of the retropiemenu folder weren't, so when I rebooted I got a message from EmulationStation that I had no systems installed. Removing the USB drive allowed the Pi to use the SD Card's data in the RetroPie folder and things worked, so to get things working I manually copied a the data from the RetroPie directory from the micro SD card to the USB drive. I then removed all of the ROMs from the Micro SD card except one, so that way it would be very obvious if the USB drive was dead when I booted, because I'd only have one game available.
                                  SSHing in to the Pi doesn't show the USB drive, but df -h shows it's alive and well.
                                       .***.     Sunday, 12 March 2017,  5:08:24 pm EDT
                                       *****     Linux 4.4.50-v7+ armv7l GNU/Linux
                                        |*|      Filesystem      Size  Used Avail Use% Mounted on
                                        |*|      /dev/root        29G  4.5G   23G  17% /
                                      ..|*|..    Uptime.............: 0 days, 00h00m31s
                                    .*** * ***.  Memory.............: 590408kB (Free) / 752856kB (Total)
                                    *******@@**  Running Processes..: 137
                                    `*****@@**'  IP Address.........:
                                     `*******'   Temperature........: CPU: 32°C/89°F GPU: 32°C/89°F
                                       `"""'     The RetroPie Project, https://retropie.org.uk
                                  $ df -h
                                  devtmpfs        364M     0  364M   0% /dev
                                  tmpfs           368M     0  368M   0% /dev/shm
                                  tmpfs           368M  5.2M  363M   2% /run
                                  tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                                  tmpfs           368M     0  368M   0% /sys/fs/cgroup
                                  /dev/mmcblk0p1   57M   21M   37M  36% /boot
                                  /dev/sda1       232G  267M  232G   1% /media/usb0
                                    tpuhlmann @jackal123uk
                                    @jackal123uk , can you tell me which is positive and which is ground on your picture? Or is it necessary? I broke my micro usb and would like to try what you did.
                                      briandamico @hansolo77
                                      @hansolo77 said in Pi in a Sega Genesis USB Hub Build:
                                      https://www.amazon.com/gp/product/B00GSE2S98/
                                      by chance do u have a link for those slider switches?
                                      are they able to capture a full slide to ON and then OFF or is it all one way and then half of the other way.
                                      have not seen much sliders in various sizes
                                        briandamico @edmaul69
                                        @edmaul69 looks like we do a lot of the same stuff ED!
                                        tell me, do u have a link for those sliders? i wanna compare to the ones i got and see if they may be better or same
                                          edmaul69 @briandamico
                                          @briandamico i posted a link somewhere but i couldnt find it. I need to contact my buddy to get a link as he was the one that ordered them.
                                            obsidianspider @briandamico
                                            @briandamico this is the link from @edmaul69 's earlier post for the switches he used.
                                            this is a link to the switch I used in my build.
