    Quick and easy guide for adding music to Emulatonstation on RetroPie. Noob friendly!
    musicbgmsynackguide
    165 Posts 59 Posters 126.3k Views
    • jonnykeshJ
      jonnykesh @SSimmers
      @ssimmers In /opt/retropie/configs/all/runcommand-onstart.sh it should say:
      pkill -STOP mpg123
      In /opt/retropie/configs/all/runcommand-onend.shit should say:
      pkill -CONT mpg123
        SSimmers @jonnykesh
        @jonnykesh Awesome! That's exactly what it was. For whatever reason, I had "/pkill -CONT mpg123". No clue why I hit the forward slash the first time around. Thanks!
        • jonnykeshJ
          jonnykesh @SSimmers
          @ssimmers Not a worry. Happy to help.
          • fnkngrvF
            fnkngrv @Cjax08
            @cjax08 no, this still plays because it is an independent application running. What I have done to deal with this is I have re-encoded all the audio files that I use in my builds to be set at 50-60% gain. This allows for the audio of the video snap to come through clearly while you can still hear the bgm "behind" it for lack of better term.
            • fnkngrvF
              fnkngrv
              anyone notice an issue where if you use the commands in bash script that music doesn't start up again when you go back into ES from terminal?
              • COOL_IRONC
                COOL_IRON
                Is it possible to create custom launch file for specific rom that will not disable music?
                  cyperghost @COOL_IRON
                  @cool_iron YES and NO
                  I created two bash files that Continous or Disable Background music by using USER MENU from runcommand. If you launch a ROM then the grey box apperas... Press a button and you enter the runcommand menu list. Now you can enable/disable Background music by using User Menu item.
                  Take a look here and add a exit 2as last line!
                  The way I descripe is not 100% the method you asked here - it's a small workaround. Of course it is possible to add music for a specific ROM.... You can modify this code and add to runcommand-onstart.sh
                  COOL_IRONC 1 Reply Last reply Reply Quote 0
                    monstergubl
                    i have done all commands on the rp3 direct
                    my big problem is where is the folder that i was created , when i type in mkdir /home/pi/bgm it say to me the folder already exists. But i cannot find the Folder on my PC or USB ...
                    • COOL_IRONC
                      COOL_IRON @cyperghost
                      @cyperghost I did not quite get it past the user menu step.
                      What should I do next? Can you explain this more please?
                      Maybe you could add some pictures?
                        @cool_iron
                        Add 2 bashfiles to dedicated folder descriped in the Wiki: runcommand functions
                        One with pkill mpg123 -STOP and the other with pkill mpg123 -CONT to User Menu. One file is called Stop BGM.SH the other is called Continue BGM.sh
                        Then you select one oft these files in User Menu and can manually enable or disable music. If you follow the link that I gave you to the bash script then you can automate the process by using a custom collection as trigger event.
                        But this needs some coding skill...
                        Feel free to ask ;)
                        • COOL_IRONC
                          @cyperghost Oh, sorry, I didn't read the topic of this discussion :P
                          The problem is that I am using different method for background music. Is it possible to make this two .sh scripts woking with this method?
                          • retroprogrammerR
                            retroprogrammer
                            This is a very good tutorial I have quiet a few tutorials to so check them out :)
                            [TUTORIAL]How to add draStic ds emulator and configure it and add ROMS with RetroPie-Manager
                            https://retropie.org.uk/forum/post/90803
                            [TUTORIAL]How to install kodi and add to main menu
                            https://retropie.org.uk/forum/post/90609
                            [TUTORIAL]How to install and use RetroPi-Manager
                            https://retropie.org.uk/forum/post/90596
                            Here is me converting the original Xbox for a case:
                            https://retropie.org.uk/forum/topic/15232/converting-original-xbox-into-case-for-raspberrypi/15
                            Check out my GitHub: https://github.com/retro-programmer
                            herb_fargusH 1 Reply Last reply Reply Quote 1
                            • herb_fargusH
                              herb_fargus administrators @retroprogrammer
                              @retroprogrammer please don't spam. The official docs are there for a reason
                                @cool_iron I think there is no problem to install mpg123 as background player just for in game music. This would be the easiest solution.... And if there are occouring problems you can easily remove it.
                                As you use the python method the python code checks for process PID of a running emulator in background so it seems to be impossible without altering python code. But that's out of my class.
                                EDIT:
                                Maybe you can act like this!
                                I think about a code like this ...
                                Enable ingame BGM.sh
                                #!/bin/bash
                                # PSEUDOCODE!
                                # DISABLE python check for running processes of emulators by pausing the python script!!!!
                                # OMXPlayer will still run in background and will play music!
                                pkill -STOP "python backgroundplayer"
                                and by editing runcommand-onend.sh you always set the -CONT condition.
                                But why don't you give the mpg123 no chance? Imho it is the easiest method for BGM but keep in mind that mpg123 is just a small player with a small bunch of command line arguments...
                                @retroprogrammer Before spamming this thread you can ask @meleu if he want's to add your tuts into his Useful topics thread
                                • retroprogrammerR
                                  retroprogrammer
                                  sorry for spamming guys just wanted to say that their are some other tutorials other sorry :(
                                    Skyfire
                                    Having some issues after getting music playing in the background via this tutorial. On launch of any ROM I am getting an audiomanger error stating the device or resource is in use. Once the game loads I have no game audio.
                                    • Z
                                      zerojay
                                      Created an alternative guide for using vgmplay instead of mpg123 to play directly emulated audio rips from game consoles and arcade machines. Much smaller file sizes than mp3s.
                                      https://retropie.org.uk/forum/topic/14682/quick-and-easy-guide-for-adding-emulated-music-to-emulationstation-on-retropie
                                      jonnykeshJ 1 Reply Last reply Reply Quote 1
                                      • jonnykeshJ
                                        jonnykesh @zerojay
                                        @zerojay How much room does it save? For example a track I use is 1:39 and 2.4MB. Would this really save a significant amount of space?
                                        • Z
                                          zerojay @jonnykesh
                                          @jonnykesh Well, put it this way, if you have a full NES game's soundtrack, let's say 20 songs in mp3 for about 3MB each song, that's 60MB. The emulated version is going to be a small part of the actual NES game's size so there's pretty much no NES game soundtrack in VGM format that will be bigger than 1MB total. Most NES games are about 200-300K for their full soundtrack in this format. Look around for VGM rips as they are a better indicator than anything I can say.
                                          • BobHarrisB
                                            BobHarris
                                            Could somebody tell me which file I have to edit (and what kind of text) to set a startsong which plays everytime when you boot up the Pi?
                                            Pi 3B , 64 GB Sandisk ultra flashdrive, 19 systems, 872 hand picked classic gaming gems :-) Dual shock 4v2
