    Quick and easy guide for adding music to Emulatonstation on RetroPie. Noob friendly!
    musicbgmsynackguide
    165 Posts 59 Posters 125.8k Views
      cyperghost @Naprosnia
      @Naprosnia You are welcome
      I will comment on your github account.
      EDIT: Added my first comment as "issue"
        @Naprosnia Added annother "Issue" for code cleanup ;) the second regards the volume control. This is a real interesting feature ;)
        As long as your coding works for you it is okay. But look if you might change a path or a call you've to edit it 10x in your scripting. With my solution it's just one edit.
        Issue #2
        Issue #1
        • N
          Naprosnia
          New version released, now with fade effect , and possibility of listen your musics while playing games.
          Special thanks to @cyperghost for the fade script!
          Video:
          cyperghostC 1 Reply Last reply Reply Quote 2
            @Naprosnia A nice set of scripts that will surly help less advanced users to quick install a mp3 BGM player. There is still room for improvements to the code but this looks much better now. You are heavily mixing shell and bash expressions together ... try to use one style.
            Btw: for variables it is not needed to seperate them
            like BGM=$PATH1"/more/pathes/"$PATH2
            just use BGM="$PATH1/more/pathes/$PATH2" so you will avoid globbing even if it's very uncommon in every other programming language I know but you will appreciate this behaviour.
            • johnholmesJ
              johnholmes
              Thank you for this nice tutorial. Have followed all instructions and i will be glad now playing my favourite music in background.
              • WarC0zesW
                WarC0zes
                @Naprosnia Nice update, I love it.
                RetroPie v4.5.1 • RPi3 Model B • NorthPada 5V 3A • 128GB SanDisk Ultra Cat.10 microSDXC • 1 x Logitech Wireless Desktop MK250 • 1 x Qanba Q4RAF USB Arcade joysticks • 1 x PS4 Dualshock4 v2 controller • 1 x Mayflash Dolphinbar + Nintendo WiiMote.
                • WarC0zesW
                  WarC0zes
                  @Naprosnia After testing, when I start a game the music is cut and when I leave the game the music doesn't come back.
                  My setting in emulationstation / Sound setting:
                  Audio card = Default
                  Audio device = PCM
                  Enable navigation sounds = On
                  Enable video audio = On
                  Omx player audio device = Both
                  BriganeB N 2 Replies Last reply Reply Quote 0
                  • BriganeB
                    Brigane @WarC0zes
                    @WarC0zes Are you using any kind of USB Sound card?
                    I cannot elaborate what my problem is at the moment because I'm in school, but I have a similar problem with my setup and I think it has to do with the fact that I'm using a USB Sound card.
                    Systems: Raspberry Pi 0/2/3 Model B+
                    Os: RetroPie 4.5
                    Frontend: Emulationstation & Attract Mode
                    • WarC0zesW
                      WarC0zes
                      @Brigane No, I don't use a USB sound card. I use that of the pi.
                      • N
                        Naprosnia @WarC0zes
                        @WarC0zes hello, i did a fresh installation on my system to check if it throw me the same problem, but no, it work normally.
                        - First, i need you to install RetroPie BGM Player again, you can install it over the current installation (dont need to uninstall).
                        [ Q. Why install again? A. Because, i have updated some code, and it could correct your problem. ]
                        -- And check if you got the same problem.
                        --- If yes:
                        ---- I need to know if this occurs with fade effect, without fade effect or both.
                        ---- I need you to check configs/all/ folder and check if you got this file-> runcommand-onend.sh
                        ----- if yes, send me the code you find inside [if any] (you can open this file with any text editor).
                        --- If no:
                        ---- Nice.
                        • WarC0zesW
                          WarC0zes
                          @Naprosnia I install again, but same problem with fade effect or without fade effect.
                          My file runcommand-onend.sh is empty (0 Ko), no error code.
                          • N
                            Naprosnia @WarC0zes
                            @WarC0zes thank for your reply, i think i found the problem.
                            Install again, i updated the online version to correct this problem, but i need someone to test.
                            If the problem persists, uninstall with uninstall.sh file that you found on github (https://github.com/Naprosnia/RetroPie_BGM_Player)
                            and install again.
                            leave some feedback please.
                            • WarC0zesW
                              WarC0zes
                              @Naprosnia
                              Install again = not works.
                              Uninstall with uninstall.sh and install again = Not works.
                              weird all works before your new update.
                              The only change I made since your update, is to steam link installed.
                              • N
                                Naprosnia @WarC0zes
                                @WarC0zes i found the problem. im writing a new fix. wait a sec. when done i tell you.
                                The problem is, sed cannot add new line to the beginning of a empty file.
                                WarC0zesW 1 Reply Last reply Reply Quote 0
                                • WarC0zesW
                                  WarC0zes @Naprosnia
                                  @Naprosnia Ok, I'm waiting for your new update ;-)
                                  • N
                                    Naprosnia @WarC0zes
                                    @WarC0zes you can install now.
                                    • WarC0zesW
                                      WarC0zes
                                      @Naprosnia it works now, thanks a lot :D
                                      • N
                                        Naprosnia @WarC0zes
                                        @WarC0zes I thank you to.
                                        • WarC0zesW
                                          WarC0zes
                                          @Naprosnia I found a bug with fade effect when I leave the game, the system volume goes to 73% or 83% instead of staying at 100%. Without fade effect it's good, it stays at 100%.
                                          • N
                                            Naprosnia @WarC0zes
                                            @WarC0zes hello, if you enter a game with 100% volume, when you leave it, the volume go to 73/83?
                                            I'll check that out.
