    Pi Zero W GBA [BUILD]
    pi zero wgbascreenbuildwip
    84 Posts 5 Posters 36.4k Views
    • spruce_m00seS
      spruce_m00se @Hex
      @hex I can show a photo at some point, but annoyingly the usb hub i built into the gameboy isnt compatible with keyboards, grrrr, that means that I need to desolder it and conenct a keyboard for some config as I had an urgent money making project (a lotof money ) last month and needed a micro sd urgently, so I robbed the one from the gameboy. now I have to reinstal the gpio pin controller setup before I can play again,
      • HexH
        Hex
        @spruce_m00se Some point is fine.
        spruce_m00seS 1 Reply Last reply Reply Quote 0
        • spruce_m00seS
          spruce_m00se @Hex
          @hex what would you like to see? the ghosting? or would you like to see the actual screen?
          • spruce_m00seS
            spruce_m00se
            I have a photo of the LCD driver board, the circled white components are Caps that get super hot, I tried to put a ceramic cap alongside them to filter out any high frequency ripple, it didnt really do anything.
            the whole thing gets so hot that it softens the hotglue thats holding it in place, and the individual caps get too hot to touch,
            • HexH
              Hex
              I think you have a short or you have not converted it properly. My LCD board used to do that when I connected to the wrong terminal. Now it runs between room temp and warm. I can keep my finger on the chipset for extended periods.
                TechieAndroid
                @spruce_m00se @Hex
                This screen you've been talking about is not the one we've been using in the build. Information not pertaining to this topic belongs in a different thread.
                • mooseprM
                  moosepr @TechieAndroid
                  @techieandroid if you change the fbtft.config and set the speed to be 80000000 (7 zeros) and add FPS=60
                  That should improve things
                  want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
                    TechieAndroid @moosepr
                    @moosepr
                    Okay cool, thanks I'll try it out.
                      TechieAndroid
                      @moosepr
                      The resolution is defaulted at 720x480, which is probably why it looks bad, I'm going to go into the config and change that to the actual resolution of the screen.
                        TechieAndroid
                        @moosepr
                        I set it to speed=90000000 fps=60 after testing it a lot and like these settings. I was wondering what resolution settings I have to choose from that applies to this screen and not the HDMI, like, I guess this screen would be analog (I don't really know I haven't looked at the spec sheet yet). I'm just trying to set everything to 320x240 which is what the screen is. Also I'm curious about changing the overscan since it appears to be off. Will that mess anything up with this screen?
                        mooseprM 1 Reply Last reply Reply Quote 0
                        • spruce_m00seS
                          spruce_m00se @Hex
                          @hex Do you have a link for a conversion tutorial? I have simply soldered the 5v input to the old output of the voltage regulator that I removed, in thoery everything after the voltage regulator is still seeinng the same voltage as before.
                          • HexH
                            Hex
                            @spruce_m00se Kindly create a new thread and tag me. This is getting off topic
                            • spruce_m00seS
                              spruce_m00se @Hex
                              @hex hold on, hahahaha
                              • mooseprM
                                @techieandroid you only need to change over scan settings if you are getting borders round your screen.
                                The screen resolution is 240x320, so setting things to that will help. The fbcp will actually scale things, so as long as the aspect ratio is correct, it shouldn't look too bad. You can also change the theme, there are many that are designed to fit the smaller screens
                                  TechieAndroid
                                  @moosepr
                                  Thanks, I turned overscan off in all the configs and set the resolution everywhere I could, it made a big difference in the terminal but emulation station stayed the same even after adding it in the es config.
                                  I've almost finished my project, all I need now is to get the buttons in.
                                  So I'm going to use the GPIO pins for them, I'll use 10 total for the GBA buttons, do I need to use any specific GPIO pins?
                                  And where do I add the code for the buttons when they are wired in?
                                  A mooseprM 2 Replies Last reply Reply Quote 0
                                    AluLagoa @TechieAndroid
                                    @techieandroid Any one in green that isn't used by the display is fine, from the following pinout.
                                    As for driver to use buttons on the GPIO, i used mk_arcade_joystick_rpi. Very easy to get working.
                                    Hope to see some pics soon.
                                    • mooseprM
                                      @techieandroid i use this for gpio buttons
                                      https://github.com/adafruit/Adafruit-Retrogame
                                        TechieAndroid
                                        @AluLagoa @moosepr
                                        Thanks guys. I've gotten everything desoldered off the GBA board. I'm trying to find the GND on the left and right sides of the board since I'm removing the center part. I'll post pics to show what I think are the correct grounds.
                                          TechieAndroid
                                            TechieAndroid
                                            I also need to remove the board from screen. There's a few resistors and capacitors, are they going to mess me up it I connect the screen solely from the ribbon cable? Also I need a schematic showing which ribbon cable pins are what, since there are untraceable.
