    ScummVM Controlller Issues
    scummvm
    168 Posts 3 Posters 36.0k Views
    • ExarKunIvE
      ExarKunIv @escc1986
      @escc1986 yes thats right.
      the event will change as things are plugged in and out
      so is you dont play to have a keyboard in there full time best to set if for event 0
      • E
        escc1986
        thank you for informing me , i had no idea ....
        ok can you clear this up with me
        which setting do i use out of these 3 settings :
        sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv
        --evdev /dev/input/by-id/[•]
        --silent
        --detach-kernel-driver
        --force-feedback
        --deadzone-trigger 15%
        --deadzone 4000
        --mimic-xpad
        --evdev-absmap ABS_[•]=x1,ABS_[•]=y1,ABS_[•]=x2,ABS_[•]=y2,ABS_[•]=lt,ABS_[•]=rt,ABS_[•]=dpad_x,ABS_[•]=dpad_y
        --evdev-keymap BTN_[•]=a,BTN_[•]=b,BTN_[•]=x,BTN_[•]=y,BTN_[•]=lb,BTN_[•]=rb,BTN_[•]=tl,BTN_[•]=tr,BTN_[•]=guide,BTN_[•]=back,BTN_[•]=start
        --silent
        --force-feedback
        --deadzone 4000
        --mimic-xpad
        --dpad-as-button
        --evdev-keymap BTN_[•]=a,BTN_[•]=b,BTN_[•]=x,BTN_[•]=y,BTN_[•]=lb,BTN_[•]=rb,BTN_[•]=tl,BTN_[•]=tr,BTN_[•]=guide,BTN_[•]=back,BTN_[•]=start,BTN_[•]=du,BTN_[•]=dd,BTN_[•]=dl,BTN_[•]=dr
        --silent
        --force-feedback
        --deadzone 4000
        --mimic-xpad
        --evdev-absmap ABS_[•]=dpad_x,ABS_[•]=dpad_y
        --evdev-keymap BTN_[•]=a,BTN_[•]=b,BTN_[•]=x,BTN_[•]=y,BTN_[•]=lb,BTN_[•]=rb,BTN_[•]=back,BTN_[•]=start
        --dpad-only
        --ui-axismap lt=void,rt=void
        --ui-buttonmap tl=void,tr=void,guide=void
        • E
          escc1986
          just dont know which template to follow that is correct for my nes controller
          that i will need to make a nano for
          nano /etc/rc.local
          • ExarKunIvE
            ExarKunIv @escc1986
            @escc1986
            i say go for the last one
            you can always cut stuff out
            and stay out of rc.local
            • ExarKunIvE
              ExarKunIv @escc1986
              @escc1986
              you will be doing your work in the runcommand.onstart
              • E
                escc1986
                kind of confused .... so i
                sudo nano /opt/retropie/configs/all/runcommand-onstart.sh
                (This template)
                --silent
                --force-feedback
                --deadzone 4000
                --mimic-xpad
                --dpad-only
                ExarKunIvE 2 Replies Last reply Reply Quote 0
                • ExarKunIvE
                  ExarKunIv @escc1986
                  @escc1986
                  close
                  you need this on the top or it will not know when to start the mapping
                  if [ "$1" = "scummvm" ]
                  then
                  sudo killall >> /dev/shm/runcommand.log 2>&1 xboxdrv
                  sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv >> /dev/shm/runcommand.log 2>&1 \
                      --evdev /dev/input/by-id/[•] \
                  • ExarKunIvE
                    ExarKunIv @escc1986
                    @escc1986
                    https://retropie.org.uk/docs/Universal-Controller-Calibration-&-Mapping-Using-xboxdrv/
                    go to the
                    Key-Mapping For Individual Emulators part to get a start on how the runcommand needs to look like
                    but for now i think you should just put your mapping in a txt on your computer.
                    there are ways to test it before you setup the run command
                    • E
                      escc1986
                      not sure what to put here
                      (the dot)
                      • ExarKunIvE
                        ExarKunIv @escc1986
                        @escc1986
                        just use the event and the number so for you it will be event0
                        i could never get the id-to work
                        think you could send me a link or something for your controller.
                        when you posted the event codes there are alot more buttons then i would of thought for a NES
                        • E
                          escc1986
                          --evdev /dev/input/by-id/event0 \
                          like so ?
                          • ExarKunIvE
                            ExarKunIv @escc1986
                            @escc1986 said in ScummVM Controlller Issues:
                            ~~--evdev /dev/input/by-id/event0 ~~
                            --evdev /dev/input/event0 \
                            • E
                              escc1986
                              my mistake , thank you ...
                              will send you the link now of my controller ...
                              is this ok :
                              then
                              --evdev /dev/input/even0
                              --silent
                              --force-feedback
                              --deadzone 4000
                              --mimic-xpad
                              --evdev-absmap ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y
                              --evdev-keymap BTN_SOUTH=a,BTN_EAST=b,BTN_[•]=x,BTN_[•]=y,BTN_[•]=lb,BTN_[•]=rb,BTN_TL2=back,BTN_TR2=start
                              --dpad-only
                              • ExarKunIvE
                                ExarKunIv @escc1986
                                is this ok :
                                then
                                --silent
                                --force-feedback
                                --deadzone 4000
                                --mimic-xpad
                                --dpad-only
                                need to fix the event. should be event0 \
                                • E
                                  escc1986
                                  ok i lied , there are 2 other buttons on the top an L and an R , im sorry i didnt include them ... i just wanted it to be simple with less buttons to map
                                  controller link
                                  https://www.nintendo.com/switch/online-service/nes/?cid=A1005-01:ch=pdpd&msclkid=0ea08d12a8f1150aaee0d3507e34c4fb
                                  • ExarKunIvE
                                    ExarKunIv @escc1986
                                    @escc1986
                                    thats fine, i was just looking at it and was theres alot here. lol
                                    • E
                                      escc1986
                                      sorry should of sent this
                                      • ExarKunIvE
                                        ExarKunIv @escc1986
                                        @escc1986
                                        it all good, lol
                                        --evdev-keymap KEY_#305=a,KEY_#304=b,KEY_#307=x,KEY_#308=y,KEY_#310=tl,KEY_#311=tr,KEY_#314=back,KEY_#315=start \
                                        this is your keymap for the controller.
                                        now with
                                        --ui-buttonmap a=BTN_LEFT,b=BTN_RIGHT,start=KEY_F5,back=KEY_ESC \
                                        you map what said buttons will do
                                        again im still messing with the dpad
                                        • E
                                          escc1986
                                          @ExarKunIv said in ScummVM Controlller Issues:
                                          #!/bin/sh
                                          Thank you ... as of right now .. it should look like this right ?
                                          #!/bin/sh
                                          then
                                          --silent
                                          --force-feedback
                                          --deadzone 4000
                                          --mimic-xpad
                                          --dpad-only
                                          f1
                                          • E
                                            escc1986
                                            i dont know why
                                            the
                                            isnt coming after event0 /
                                            when i post the template
                                            it doesnt matter ... only matters when i really save it on the pi
                                            thanks for pointing that mistake out to me
