    ScummVM Controlller Issues
    scummvm
    168 Posts 3 Posters 27.6k Views
    • ExarKunIvE
      ExarKunIv @escc1986
      @escc1986
      when you post something like that
      put ```
      before and after
      then it will come up with the colored box around it
      like this
      just to help
      • E
        escc1986
        @ExarKunIv said in ScummVM Controlller Issues:
        like this
         ``` like this
        humm didnt work for me
        i donkt know .. i guess it doesnt matter ... sorry for the bother
        ohhhhh got it !!!!
        • ExarKunIvE
          ExarKunIv @escc1986
          @escc1986 nice
          • E
            escc1986
            Thank you
            so with that button modiyfed
            it didnt seem to work
            i pasted it
            i rebooted
            and its the same
            the buttons
            start doesn not work
            select doesnt not work
            B button works for left mouse click
            A Does not work
            with the new button lay out it didnt change anything ... i dont know .. werid
            • ExarKunIvE
              ExarKunIv @escc1986
              @escc1986
              post what you pasted here how i showed you
              • E
                escc1986
                im trying , i cant .. keep saying its spam
                ExarKunIvE 2 Replies Last reply Reply Quote 0
                • ExarKunIvE
                  ExarKunIv @escc1986
                  @escc1986
                  lol
                  hit enter after fi for what you just posted
                  • E
                    escc1986
                    i cant seem to do it .. hummmm
                    #!/bin/sh
                    if [ "$1" = "scummvm" ]
                    then
                    sudo killall >> /dev/shm/runcommand.log 2>&1 xboxdrv
                    sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv >> /dev/shm/runcommand.log 2>&1 \
                    --evdev /dev/input/event0 \
                    --silent
                    --detach-kernel-driver
                    --force-feedback
                    --deadzone-trigger 15%
                    --deadzone 4000
                    --mimic-xpad
                    --evdev-absmap ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y
                    --evdev-keymap BTN_EAST=a,BTN_SOUTH=b,BTN_[•]=x,BTN_[•]=y,BTN_[•]=lb,BTN_[•]=rb,BTN_TL2=back,BTN_TR2=start
                    --dpad-only
                    --ui-axismap lt=void,rt=void
                    --ui-buttonmap a=BTN_LEFT,b=BTN_RIGHT,start=KEY_F5,back=KEY_ESC \
                    f1
                    • ExarKunIvE
                      ExarKunIv @escc1986
                      @escc1986
                      my bad
                      use the key next to the 1
                      thats the key you want
                      • ExarKunIvE
                        ExarKunIv @escc1986
                        @escc1986 perfect
                        • E
                          escc1986
                          how does it look ... did i do it right ?
                          • ExarKunIvE
                            ExarKunIv @escc1986
                            @escc1986
                            its a start.
                            now we need to get it to work.
                            • E
                              escc1986
                              i dont know why the buttons are not correctly working
                              i dont understand
                              we didnt map the 2 top buttons l button and r button
                              L = Space
                              R = f5
                              what is going on with this controller
                              • ExarKunIvE
                                ExarKunIv @escc1986
                                @escc1986
                                the f5 you do. thats how you bring up the menu in scrumm to save and quit
                                • E
                                  escc1986
                                  yeah the f5 button is very importyant , your right
                                  i just dont see how f5 is mapped to the
                                  R Button
                                  i didnt map
                                  R button
                                  or
                                  L button
                                  do you know why they are mapped .. and the other button are not mapped
                                  TL2 = SELECT
                                  TR2 = START
                                  on my controller under test menu (evtest /dev/input/event0)
                                  • E
                                    escc1986
                                    video of showing you
                                    https://dropmefiles.com/vTVGk
                                    • ExarKunIvE
                                      ExarKunIv @escc1986
                                      @escc1986
                                      --ui-buttonmap a=BTN_LEFT,b=BTN_RIGHT,start=KEY_F5,back=KEY_ESC \ this came from my setup, since you need these for play anyways
                                      the rest is on you
                                      BTN_[•] this just means its blank till you add what button goes to it
                                      this is what you have
                                      so far the buttons you have mapped are btn east and south, and your TL buttons
                                      thx for the vid.
                                      this is a good thing cuz it is working, we just need to get the keys to do what we want
                                      the big part is getting the dpad to work.
                                      bad part is my xdrive is now not working. so i cant test it on mine just yet
                                      • E
                                        escc1986
                                        you welcome for the video
                                        but i dont have an X , Y , LB , RB button
                                        ok let me see
                                        ok
                                        R button = Z
                                        L Button = WEST
                                        --evdev-keymap BTN_EAST=a,BTN_SOUTH=b,BTN_[•]=x,BTN_[•]=y,BTN_WEST=lb,BTN_Z=rb,BTN_TL2=back,BTN_TR2=start
                                        • ExarKunIvE
                                          ExarKunIv @escc1986
                                          @escc1986
                                          yeah the swtich controller have some messed up names for the buttons.
                                          once you find out what name goes with what button then you can map it
                                          use a note pad and write it down as you press them thats what i did
                                          • ExarKunIvE
                                            ExarKunIv
                                            heres what i have at the moment, i cant test cuz my xdriv is just not working now.
                                            change the buttons maps at you need them, but i hope that the dpad will work, cuz thats more on what i was working on
                                            then
                                            sudo killall > /dev/null 2>&1 xboxdrv
                                            sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv > /dev/null 2>&1 \
                                               --silent \
                                            	--detach-kernel-driver \
                                            	--force-feedback \
                                            	--mimic-xpad \
                                            	--trigger-as-button \
                                            	--evdev-absmap ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
                                                --evdev-keymap BTN_EAST=a,BTN_SOUTH=b,BTN_[•]=x,BTN_[•]=y,BTN_[•]=lb,BTN_[•]=rb,BTN_TL2=back,BTN_TR2=start \
                                            	--ui-axismap dpad_x=REL_X:10,dpad_y=REL_Y:10 \
                                            	--ui-buttonmap guide=void,x=void,y=void,lb=void,rb=void,tl=void,tr=void,lt=void,rt=void, \
                                            fi
