    N64 not working
    n64helpportable piretropie
    39 Posts 3 Posters 39.8k Views
      mediamogul Global Moderator @silence0101
      @silence0101
      Which emulator is selected?
      • silence0101S
        silence0101
        mupen64plus-videocore
          @silence0101
          The videocore option shows promise for the future, but as of now, I've yet to get a game to run. Try the Glide or Rice options instead.
          • silence0101S
            silence0101
            hi res or low res? tried glide not working still fuzzing up then going back to the menu i think its a video problem is there anything else i can change?
              @silence0101
              I can reliably make use of both, but why don't you start off by trying low.
              • silence0101S
                silence0101
                low res didn't work i think its a video problem is there anything else i can change?
                  @silence0101
                  You can try some more default video modes. Also, you might try retracing all the steps that led to this issue for possible clues.
                  • silence0101S
                    silence0101
                    DUDE I WANNA FREEKING MARRY YOU IT WORKS!
                    Damm! now The Keyboard Won't register
                      @silence0101
                      Can I keep my maiden name?
                      • silence0101S
                        silence0101
                        Lol but do u know how i could fix this keyboard thingy. the only file
                        in /opt/retropie/configs/n64/ is the emulators
                          @silence0101
                          Have you tried uninstalling and reinstalling Mupen64Plus, or is that what started your video problems? I'm not sure where we landed on that.
                          • silence0101S
                            silence0101
                            so i fixed the video but the keyboard is still not working and how would i reinstall mupen64plus also i think the keyboard has been doing this since i started the pi up but only with the n64 tho i may have changed a setting when i first started it up
                              @silence0101
                              The instructions for installing are here. You'll first want to choose the 'Remove' option and then follow it up with 'Install from binary'. If that doesn't add the /opt/retropie/configs/n64/InputAutoCfg.ini file, then it might have either been removed purposefully by the development team for one reason of another, or is not being included by accident.
                              silence0101S 1 Reply Last reply Reply Quote 0
                              • silence0101S
                                silence0101 @mediamogul
                                @mediamogul said in N64 not working:
                                @silence0101
                                The instructions for installing are [here](https://github.com/RetroPie/RetroPie-Setup/wiki/First-Installation#installing-additional-emulators--ports). You'll first want to choose the 'Remove' option and then follow it up with 'Install from binary'. If that doesn't add /opt/retropie/configs/n64/InputAutoCfg.ini, then it might have either been removed purposefully by the development team for one reason of another, or is not being included by accident.
                                the here just redirects me to here. yeah and theres no inpitautocfg.ini
                                  @silence0101
                                  Fixed link
                                  • silence0101S
                                    silence0101
                                    thanks gtg il tell u later if its fixed thanks!
                                    • silence0101S
                                      silence0101
                                      i did it but it only came up with install from code or core or something like that then it tried reinstalling it and came up with a ton of errors now when i launch the n64 it says no config file for n64
                                      • silence0101S
                                        silence0101
                                        @mediamogul
                                        I'm gonna just reset the whole pi so will see what happens
                                        i reset the pi and still the keyboard wont work and no new config file
                                        • silence0101S
                                          silence0101
                                          tried setting up Xbox one controller and works fine thanks for the help mate!
