    I have a challenge! Help me !
    psxpcsxpcsx rearmedlr-pcsx-rearmednot working
    61 Posts 14 Posters 21.7k Views
    • N
      Nismo @mediamogul
      @mediamogul yes I tested on Windows but I think libretro cores are cross platform
      and the same improvements in all systems.
        mediamogul Global Moderator @Nismo
        @Nismo
        I might be misunderstanding you, but the Mednafen PSX RetroArch core isn't available for RetroPie.
        • N
          Nismo @mediamogul
          @mediamogul I didn't know that core was not available. What cores available for psx in retropie then?
            @Nismo
            lr-pcsx-rearmed
            pcsx-rearmed
            lr-beetle-psx
              dankcushions Global Moderator @mediamogul
              @mediamogul said in I have a challenge! Help me !:
              @Nismo
              lr-pcsx-rearmed
              pcsx-rearmed
              lr-beetle-psx
              beetle is mednafen. they renamed it for whatever reason.
              but... only pcsx-rearmed has an ARM dynarec, which means only those two cores will give playable performance on a pi system.
              N 1 Reply Last reply Reply Quote 2
              • N
                Nismo @dankcushions
                @dankcushions Then can somebody try with beetle even with poor performance? just to see if it boots.
                Pcsx has not as good compatibility as mednafend psx/beetle.
                  @Nismo said in I have a challenge! Help me !:
                  I tried it with the same European BIOS that worked on my desktop machine, but it didn't do anything.
                  N 1 Reply Last reply Reply Quote 1
                  • N
                    Nismo @mediamogul
                    @mediamogul Strange... But @horaciowm seems to forget that emulators are not 100% compatible with all games, and not all games work the same in every emulator.
                    • H
                      horaciowm @Nismo
                      @Nismo Sad..
                      • H
                        horaciowm
                        Anyone has another Idea?
                          machuna @horaciowm
                          @horaciowm Hello, I register just to be able to comment on this post.
                          I am also desperate, all the games work except the ISS200.
                            pjft @machuna
                            @machuna wow. I can't believe so many people are looking for the same game. We should form a club! :)
                            Indeed, I had a hard time tracking down the game because even though I have the original CD here and can play it on my ps3, I no longer have a CD drive on my laptop for a few years now, and the game isn't released as "ISS 2000" here in Europe, but only ISS, which matches all the ISS PRO games instead:)
                            Yes, I confirm the same. I have tested it exhaustively back in September and then around Christmas time after updating the emulator from source. Nothing helped.
                            Was hopeful that the latest update would help but I see no commits there whatsoever that would seem to help.
                            Might be worth posting a bug at the actual emulator project:
                            https://github.com/notaz/pcsx_rearmed/issues
                            Best.
                              thepk
                              Try and download it from a different website like [Redacted: read the forum rules].
                                A Former User
                                [Redacted: read the forum rules] sounds like a pretty good website.
                                • N
                                  Nismo @thepk
                                  @thepk The game it's not working in pcsx-rearmed, (it works on windows emulators), downloading the game from other websites will not make the game magically works.
                                    machuna @pjft
                                    @pjft Hello! ISO already found it. I have several.
                                    But none works.
                                      pjft @machuna
                                      @machuna As I said, it doesn't matter the format. The game does not work on the emulator at the moment. Period.
                                      We can only hope that either:
                                      a) there are new developments in the emulator that will allow it to run, or
                                      b) a new emulator comes up.
                                      I tried both the European and the Japanese releases, with no luck.
                                        BuZz administrators @Nismo
                                        @Nismo is that link to cdimage freeware ?
                                        • N
                                          Nismo @BuZz
                                          @BuZz it's freeware program, but a little difficult to find nowadays.
                                          Edit: found, here you can see "program license free" https://cdmage-beta.jaleco.com/.
                                            @Nismo thanks. Your post got flagged so just wanted to confirm.
