    Pi in a Dreamcast VMU Build - WIP
    buildprojecthandheldvmudreamcast
    157 Posts 7 Posters 94.4k Views
      obsidianspider @moosepr
      @moosepr Aww man, all I have is this perf board. I hope it'll work.
      πŸ“· @obsidianspider
      mooseprM 1 Reply Last reply Reply Quote 0
      • mooseprM
        moosepr @obsidianspider
        @obsidianspider you should be able to fit the pi, the screen, and the 10 charger boards on there :P
        want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
          @moosepr Now you're playing with Power!
          • mooseprM
            @obsidianspider as long as it doesnt end up as playing with fire, then its all good!
              @moosepr I'm looking more into the ILI9163 screen driver issue, and it looks like the Arduino community has seen these before. I'm wading though a long thread, but I'm not sure how helpful it ill be.
              • mooseprM
                @obsidianspider just for the hell of it, try this as your fbtft.conf
                options fbtft_device name=flexfb width=128 height=160 speed=40000000 init=-1,0x01,-2,150,-1,0x11,-2,500,-1,0xB1,0x01,0x2C,0x2D,-1,0xB2,0x01,0x2C,0x2D,-1,0xB3,0x01,0x2C,0x2D,0x01,0x2C,0x2D,-1,0xB4,0x07,-1,0xC0,0xA2,0x02,0x84,-1,0xC1,0xC5,-1,0xC2,0x0A,0x00,-1,0xC3,0x8A,0x2A,-1,0xC4,0x8A,0xEE,-1,0xC5,0x0E,-1,0x20,-1,0x36,0xC0,-1,0x3A,0x05,-1,0xE0,0x0f,0x1a,0x0f,0x18,0x2f,0x28,0x20,0x22,0x1f,0x1b,0x23,0x37,0x00,0x07,0x02,0x10,-1,0xE1,0x0f,0x1b,0x0f,0x17,0x33,0x2c,0x29,0x2e,0x30,0x30,0x39,0x3f,0x00,0x07,0x03,0x10,-1,0x29,-2,100,-1,0x13,-2,10,-3
                its basically what notro mentioned in his message https://github.com/notro/fbtft/wiki/flexfb#sainsmart-18-st7735r
                  @moosepr said in Pi in a Dreamcast VMU Build - WIP:
                  No dice. I just get a white screen with that.
                  I went back to options fbtft_device name=fb_ili9163 gpios=reset:25,dc:24 speed=40000000 bgr=1 rotate=0 custom=1 fps=60 and while I have the junk pixels on the bottom and right, at least I have output to the display.
                  Just to be thorough I went into /boot/config.txt and commented out the bits that I put in to change the resolution to 128x128 and that didn't affect the garbage pixels. It did get games to take up the entire screen (aside from the right and bottom) again, so at least I know I can tweak that once I get the pixel addressing figured out.
                  In looking at various screens online, it's impossible to know which one you're going to get. All of the different websites and sellers use the same photo and descriptions.
                  The snazzy $40 Adafruit OLED is also out of stock, so that's not really an option, even if I wanted to spend $40 on a tiny screen, which I don't.
                    I'm going to tinker with the driver more, but this is what things look like with the proper aspect ratio inside the VMU case. I am probably going to make a bezel out of black electrical tape to hide the white case from the screen, and while I'm doing it, covering up those bad pixels won't kill me. It'd be a hack, crappy solution, but it'd work.
                    Next up I'm going to remove a screen from the PCB and see if I can get that working connected to my test Pi.
                    • mooseprM
                      @obsidianspider yeah I got the same with that code, I was just hoping you might get lucky as you have a slightly different screen
                      The big chunk of code has some logic, -1 is for sending a command to the screen, -2 is for a delay, and -3 is the end of message. I need to find some time to compare that string with the commands that are in the 2 drivers that kinda work, and see if I can get the flex one working. I think my boards will be with me early next week, so once I have one soldered up I will be in need of a working driver!
                        @moosepr I believe in you.
                          After spending another few hours trying to get rid of the garbage pixels, I'm going to try ordering screens from a different seller, also located in China. At $3.50/each, I've spent well more than that in the amount of time I've been farting around with parameters and drivers. The first screens will be getting added to the parts bin. In the mean time I can use one to mock up component placement.
                          I also ordered some piezos from digi-key. Those will be here much quicker as they're from a US seller.
                          I have some power switches, so that won't be an issue, but I do still need to sort out the battery situation. It looks like a 500mAh one from Adafruit will work, but they are currently out of the Powerboost 500C that I want for another build, so I'll be waiting until that's in stock because Adafruit has a pretty hefty minimum shipping charge and I want to group things into as few orders as possible.
                            Today the postal carrier dropped off a small package from China. Inside were three little screens, with a minor difference on the back. These said "v2.1".
                            …and they WORK!
                            No garbage pixels. Plus, these came with plastic screen protector film on them. The first screens did not. Oh well, money wasted on those unless I can figure out another driver.
                            If you're an instagram kind of person, here's a short video of it working.
                            Next up I'll be trying to remove one of the new working screens from the board and wire that up.
                            satri360S 1 Reply Last reply Reply Quote 4
                            • ArvesterA
                              Arvester
                              I follow your build from some time now, and started to buy all pieces a few days ago. I hope the screens I bought are the new version !
                                obsidianspider @Arvester
                                @Arvester Unfortunately with these cheap boards there are tons of variants and it's almost impossible to know which one you're going to get. Good luck!
                                • satri360S
                                  satri360 @obsidianspider
                                  @obsidianspider Wonderful! I've got V1.1 LCD and also have the garbage pixels. Need to find a way to fix/conceal as I have 5pcs of them...
                                    obsidianspider @satri360
                                    @satri360 since the 1.44" screen doesn't fill the entire opening I was going to make a bezel either out of black electrical tape or thin plastic so you don't see the white part. I figured if the v2.1 screens didn't fix the issue I would just make the bezel slightly larger to cover those rows. It's a bit hacky, but I figure it's not much different than how on older CRT televisions there was often a region of the picture tube that you didn't see due to the case, etc.
                                    • ArvesterA
                                      Arvester
                                      So, do you have a reference about what battery could fit ?
                                      For now, I have the VMU and the Pi Zero, I'm waiting for the screens to arrive (probably next week).
                                        @Arvester said in Pi in a Dreamcast VMU Build - WIP:
                                        I haven't gotten that far yet. I have an idea of what may fit, but I need to fit things into my test case and measure.
                                        • ArvesterA
                                          Arvester
                                          Have you seen that ?
                                          https://www.adafruit.com/product/910
                                          It would fit vertically, but needs power boost to achieve 5V. And then it would be 160x240px, much more than the 128x128 we found anywhere else.
                                          obsidianspiderO mooseprM 2 Replies Last reply Reply Quote 0
                                            @Arvester It would not be a perfect fit. The 1.44" screen barely fits as it is, and that screen also has a huge logic board that would take up a ton of room we don't have. It's also $40 for one screen. I paid $3 for one of the 1.44" screens.
