    Pi in a Dreamcast VMU Build - WIP
    buildprojecthandheldvmudreamcast
    157 Posts 7 Posters 95.8k Views
    • cellyC
      celly @obsidianspider
      @obsidianspider yes! Glad you got it all. Can't wait to see the finished product.
      Currently Playing: Tetris (Gameboy)
        ABrugsch
        are those actual Garbage Pail Kids? wow memories!
        (or do they still make them?) one of the things that annoyed me moving from USA to UK as a kid was that the garbage pail kids got smaller, and went from having a cutout shape for the sticker part to just being fully rectangular. I think I ended up throwing my collection away, or just sticking them to things...
          obsidianspider @ABrugsch
          @ABrugsch They're Garbage Pail Kids!
          πŸ“· @obsidianspider
            My screens showed up in the mail today!
            No protective stickers over the actual display itself, so hopefully the minor imperfections I'm seeing on both screens are just some dirt.
            A quick mockup of setting a screen inside a VMU looks very promising.
            mooseprM 1 Reply Last reply Reply Quote 1
            • mooseprM
              moosepr @obsidianspider
              @obsidianspider chip at the top sure it better!! plus the driver being upside down to begin with, means not having to worry about changing it!
              want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
                obsidianspider @moosepr
                @moosepr Now I'm trying to figure out what GPIO pins map to the pins on the red board.
                mooseprM 1 Reply Last reply Reply Quote 0
                • mooseprM
                  @obsidianspider is this any use?
                  linez
                    @moosepr This is about where I'm at. Your diagram helps quite a bit. I'll have to see if I can follow the traces and translate that to the pins on the red board before I try soldering things up. I want to make sure things work stock before I take it apart.
                    • mooseprM
                      @obsidianspider lets see if i can fill in the blanks for you
                      1 - 3.3v
                      2 - gnd
                      3 - gpio 8 (pin 24)
                      4 - gpio 25 (pin 22)
                      5 - gpio 24 (pin 18)
                      6 - gpio 10 (pin 19)
                      7 - gpio 11 (pin 23)
                      8 - 3.3v (can be the same as pin 1)
                      my schematic is a little messy, lots of crossovers. tis something i need to refine
                      obsidianspiderO 2 Replies Last reply Reply Quote 0
                        @moosepr Well, it looks like I came up with the same answer, so that's good. Now I need to tweak a RetroPie setup to see if I can get things working!
                        • mooseprM
                          @obsidianspider thats the easy bit
                          raspi-config - enable spi
                          sudo nano /etc/modules - add in
                          spi-bcm2835
                          fbtft_device
                          sudo nano /etc/modprobe.d/fbtft.conf - add in
                          options fbtft_device name=fb_ili9163 gpios=reset:25,dc:24 speed=40000000 bgr=1 rotate=0 custom=1 fps=60
                          reboot
                            @moosepr I'm workin on it! I'm workin on it!
                              So, it works, kind of. Both screens are showing garbage data on the pixels on the right, one is showing them on the bottom as well. I haven't tried adjusting resolution yet, but the screen is mirroring what's going to HDMI correctly, aside from the garbage pixels.
                              I do have overscan disabled in /boot/config.txt
                                @obsidianspider do the dead pixels show up under the VMU bezel?
                                • mooseprM
                                  @obsidianspider hmmm are those the 128x128 screens, or the 128x160?
                                    @moosepr they're the "red board" screens.
                                    Setting the HDMI resolution to 128 x 128 in /boot/config.txt didn't help.
                                    Great refresh rate though. Very smooth.
                                    @lilbud The whole screen shows. I'm going to actually end up coloring in the white surround black to hide it a bit. This is just "set in" but you get the idea.
                                    • mooseprM
                                      @obsidianspider just for shits and giggles, try running it with the other driver
                                      options fbtft_device name=fb_st7735r gpios=reset:25,dc:24 speed=40000000 bgr=1 rotate=0 custom=1 fps=60
                                      then if that works, try adding some size in there
                                      options fbtft_device name=fb_st7735r gpios=reset:25,dc:24 speed=40000000 height=128 bgr=1 rotate=0 custom=1 fps=60
                                      all in sudo nano /etc/modprobe.d/fbtft.conf of course
                                        @moosepr That gave me a different kind of garbage. The bad pixels moved to the other side, things are upside down, and the bottom output is garbled.
                                        mooseprM 2 Replies Last reply Reply Quote 0
                                        • mooseprM
                                          @obsidianspider odd!! it behaves differently to the one i have got. Although mine is probably wired differently (you may also have a totally different screen on the board)
                                          notro did point me in the direction of using the flex driver, where you can basically set the full init commands. I did start looking, but decided to wait till my boards arrived (they have literally just been marked as shipped!!)
                                          here is all i know so far https://github.com/notro/fbtft/issues/453
                                          • mooseprM
                                            @obsidianspider Mine have H144TC215A-V0 on the ribbon
