    Pi in a Dreamcast VMU Build - WIP
    buildprojecthandheldvmudreamcast
    157 Posts 7 Posters 96.6k Views
    • mooseprM
      moosepr @obsidianspider
      @obsidianspider yeah im working on that!! apparently its a known issue. going to have a play with the st7735 driver and see if i can make it work 128x128
      https://github.com/notro/fbtft/issues/453
      want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
      obsidianspiderO 1 Reply Last reply Reply Quote 3
        obsidianspider @moosepr
        @moosepr That'd be cool if you got the other one to work at the proper resolution. Apparently those red boards are set wrong and you have to trick them into behaving properly.
        • This display:
        • http://www.ebay.com/itm/Replace-Nokia-5110-LCD-1-44-Red-Serial-128X128-SPI-
        • Color-TFT-LCD-Display-Module-/271422122271
        • This particular display has a design error! The controller has 3 pins to
        • configure to constrain the memory and resolution to a fixed dimension (in
        • that case 128x128) but they leaved those pins configured for 128x160 so
        • there was several pixel memory addressing problems.
        • I solved by setup several parameters that dinamically fix the resolution as
        • needit so below the parameters for this display. If you have a strain or a
        • correct display (can happen with chinese) you can copy those parameters and
        • create setup for different displays.
        • mooseprM
          moosepr
          running on st7735r the screen is the right way round, but too tall
          options fbtft_device name=fb_st7735r gpios=reset:25,dc:24 speed=40000000 bgr=1 rotate=0 custom=1 fps=60
          (see the bar is not centred)
          so if i add some screen size in there
          options fbtft_device name=fb_st7735r gpios=reset:25,dc:24 speed=40000000 height=128 bgr=1 rotate=0 custom=1 fps=60
          (the shape is better, but i have my hunk of garbage back)
          • mooseprM
            moosepr
            there is of course an easy answer!!!! go back to the original 'proper' driver and just flip the pi!!!
            please excuse the cat hair!!!
              @moosepr What do you mean by "flip the Pi"? You're rotating the display output somewhere else?
              Based on your findings, which driver is "better"? Considering we can get the orientation now working with the right resolution and with the pins at the top or the bottom.
              mooseprM 1 Reply Last reply Reply Quote 0
              • mooseprM
                @obsidianspider if you add into config.txt
                display_rotate=2
                then it rotates the pi display 180 degrees
                i think for now, the ili9163 driver is the winner, as the resolution is correct. rotating the screen is a solution for now, but it destroys the option of keeping the hdmi output as an option. i will see what notro can come up with. he is a bit of a legend when it comes to the tft's!!
                  @moosepr No need for HDMI out on my builds (for now) so I think I know which driver I'll be messing with once things arrive.
                  • mooseprM
                    @obsidianspider i think after 2 weeks of china post, we will have a better fix :)
                    • cellyC
                      celly @obsidianspider
                      @obsidianspider i'm following this as I'm a big fan of the DC system and would love to see you put your magic to it. I have 2 spare VMU's from my DC i can donate if you need.
                      Currently Playing: Tetris (Gameboy)
                        obsidianspider @celly
                        @celly Thanks for that, but I don't think I'll need to cut up yours. I ordered two blue ones for $6 each on eBay and they should be here by Saturday. I would have loved to have found a white one for cheap, but those are selling for a lot more, and most don't have the dust caps.
                        As an example, here's one for $15 but I really don't want to spend that much for something so tiny just to cut up.
                          ABrugsch
                          Yeah there seem to be an abundance of the translucent blue, green and a couple of other colours all BNIB doing the bay at the moment.
                            obsidianspider @ABrugsch
                            @ABrugsch I have to wonder where they're all coming from since the Dreamcast was only produced until 2001. The ones I ordered are theoretically brand new in the box.
                            • mooseprM
                              @obsidianspider maybe they made way more than they needed. Or maybe we invent a time machine in the not too distant future, and go back and tell them to make more, so there are plenty left for pi related shenanigans
                                lilbud @moosepr
                                @moosepr The things I could do with a time machine...
                                  obsidianspider @lilbud
                                  @lilbud
                                  lilbudL cellyC 2 Replies Last reply Reply Quote 3
                                    lilbud @obsidianspider
                                    @obsidianspider No, I already got a list.
                                    • Buy brand new copies of rare games, (Earthbound, Panic Restaurant, Stadium Events, etc.) and sell them in the present day for a shitload of money
                                    • Go back and stop my dad from falling and crushing his arm.
                                    • Find out who let the dogs out
                                    • cellyC
                                      @obsidianspider ok man, offer still stands. I found 2 loose ones. 1 with the cover and one without.
                                      check it
                                        @celly Oh wow, those are in really good shape too. I would feel bad not paying anything for them. What's the best way to message you, since the forum doesn't allow private messaging?
                                        • cellyC
                                          celly
                                          @obsidianspider Um, on the GameEx site, same user name. Send me a pm over there and we can figure something out.
                                            @celly
