    Guide: Advanced Controller Mappings
    joystickcontrollermappingxboxdrvscummvm
    626 Posts 35 Posters 508.1k Views
    • ExarKunIvE
      ExarKunIv @mediamogul
      @mediamogul
      ok cool
      i will give that a shot and see if i get anything to build on
      • ExarKunIvE
        ExarKunIv
        i think this looks right from what you said
        input_device = "Xbox 360 Wireless Receiver (XBOX)"
        input_driver = "udev"
        input_r_y_plus_axis = "+4"
        input_l3_btn = "9"
        input_r_x_minus_axis = "-3"
        input_l_btn = "4"
        input_load_state_btn = "4"
        input_start_btn = "7"
        input_exit_emulator_btn = "7"
        input_l_y_minus_axis = "-1"
        input_up_btn = "13"
        input_r_y_minus_axis = "-4"
        input_a_btn = "1"
        input_b_btn = "0"
        input_reset_btn = "0"
        input_down_btn = "14"
        input_l_x_plus_axis = "+0"
        input_l_y_plus_axis = "+1"
        input_r_btn = "5"
        input_save_state_btn = "5"
        input_r2_axis = "+5"
        input_r3_btn = "10"
        input_right_btn = "12"
        input_state_slot_increase_btn = "12"
        input_key_1 = "3"
        input_menu_toggle_btn = "3"
        input_select_btn = "6"
        input_enable_hotkey_btn = "6"
        input_l_x_minus_axis = "-0"
        input_y_btn = "2"
        input_left_btn = "11"
        input_state_slot_decrease_btn = "11"
        input_r_x_plus_axis = "+3"
        input_l2_axis = "+2"
        input_remapping_directory = "/opt/retropie/configs/videopac/"
        input_player1_joypad_index = "1"
        input_player2_joypad_index = "0"
        input_player2_analog_dpad_mode = 1
        • ExarKunIvE
          ExarKunIv
          ok this is a good head turner
          and it switchs my 8BitDo to player 2
          if i change it to this
          input_player1_joypad_index = "0"
          input_player2_joypad_index = "1"
          its player 1 again
          and here is what i got when i ran the script
          pi@retropie:~ $ xboxdrv 0.8.8 - http://pingus.seul.org/~grumbel/xboxdrv/
          Copyright © 2008-2011 Ingo Ruhnke <grumbel@gmail.com>
          Licensed under GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
          This program comes with ABSOLUTELY NO WARRANTY.
          This is free software, and you are welcome to redistribute it under certain
          conditions; see the file COPYING for details.
          Your Xbox/Xbox360 controller should now be available as:
            /dev/input/js1
            /dev/input/event3
          Press Ctrl-C to quit
          Shutdown complete
          not really sure where to go from here.
            mediamogul Global Moderator @ExarKunIv
            @ExarKunIv
            That appears to indicate a successful launch of xboxdrv. Are you saying that it stays on that screen indefinitely? Post your script and we'll take a look.
            • ExarKunIvE
              @mediamogul
              it says up until i exit a game, turn off my controller, or press ctrl c
                  --evdev /dev/input/event2 \
                  --silent \
              	--detach-kernel-driver \
              	--force-feedback \
              	--mimic-xpad \
                      --deadzone 15% \
              	--evdev-no-grab \
              	--evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_Z=x2,ABS_RZ=y2,ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
              	--evdev-keymap KEY_#304=a,KEY_#305=b,KEY_#307=x,KEY_#308=y,KEY_#312=lt,KEY_#313=rt,KEY_#310=lb,KEY_#311=rb,KEY_#317=tl,KEY_#318=tr,KEY_#314=back,KEY_#315=start \
              	--axismap -Y1=Y1,-Y2=Y2 \
                      --ui-buttonmap a=KEY_UNKNOWN,b=KEY_UNKNOWN,start=KEY_UNKNOWN,back=KEY_UNKNOWN,x=KEY_UNKNOWN,y=KEY_UNKNOWN,lt=KEY_UNKNOWN,rt=KEY_UNKNOWN,lb=KEY_UNKNOWN,rb=KEY_UNKNOWN,tl=KEY_UNKNOWN,tr=KEY_UNKNOWN \
              	--ui-axismap x2=KEY_1:KEY_2,Y2=KEY_3:KEY_4 \
              is that i manually add
              the shutdown complete was just from me exiting the game.
              other then no errors coming up i get no mapping down. i still need my usb keyboard in to press 1
                @ExarKunIv
                I've only ever known the screen to stay like that when the '&' is left off the tail end of the xboxdrv launch script. If that were the case, pressing 'Ctrl-C' would stop xboxdrv and allow things to move forward without the map being active, which would explain why it's not accessible once the emulator is up. You've posted the command itself, but can you post it in context with how it's being launched from runcommand-onstart.sh?
                • ExarKunIvE
                  @mediamogul
                  if [ "$1" = "Videopac" ]
                  then
                  sudo killall > /dev/null 2>&1 xboxdrv
                  sudo /opt/retropie/supplementary/xboxdrv/bin/xboxdrv > /dev/null 2>&1 \
                      --silent \
                  	--force-feedback \
                  	--mimic-xpad \
                          --deadzone 15% \
                  	--evdev-no-grab \
                  fi
                  sorry for the delay
                  busy nite
                    @ExarKunIv
                    Everything appears to be OK. The only thing I can even guess is that there might be something else in runcommand-onstart.sh that may be conflicting in some way.
                    • ExarKunIvE
                      @mediamogul
                      ok ill pull out the other configs and see that i get
                      • ExarKunIvE
                        ExarKunIv
                        ok i pulled everything out of my runcommand-onstart.sh
                        and still got nothing. so i ran cat /proc/bus/input/devices
                        and got this
                        I: Bus=0005 Vendor=3810 Product=0009 Version=0100
                        N: Name="8Bitdo FC30 Pro"
                        P: Phys=b8:27:eb:47:c7:78
                        S: Sysfs=/devices/platform/soc/3f201000.uart/tty/ttyAMA0/hci0/hci0:11/0005:3810:0009.0003/input/input8
                        U: Uniq=e4:17:d8:7a:6a:7d
                        H: Handlers=js0 event0
                        B: PROP=0
                        B: EV=1b
                        B: KEY=ffff0000 0 0 0 0 0 0 0 0 0
                        B: ABS=30627
                        B: MSC=10
                        the event code is different. so i went in and changed it in my script
                        then
                            --evdev /dev/input/event0 \
                            --silent \
                        	--force-feedback \
                        	--mimic-xpad \
                                --deadzone 15% \
                        	--evdev-no-grab \
                        fi
                        sadly nothing, but i can test it my controller using evtest /dev/input/event0
                        and i get reading, but nothing showing any mapping. :(
                        so it still seems that the --evdev-no-grab \ is working too well
                        edit
                        i know why the event number changed so no big on there
                        • ExarKunIvE
                          ExarKunIv
                          update
                          my mapping works, i move my right joystick and i get KEY_1, KEY_2 ect..and when i exit the evtest /dev/input/event1 goes away showing that it see that i have exited the same, and the --evdev-no-grab \ works as i can move with in the game just fine....as long as i have a usb keyboard to press 1 for me.
                          for some reason it will not see my mapping as a valid key press
                          now im confused.
                            @ExarKunIv
                            Ah, OK. I think I know what's wrong. Take a look at the final part of section 3A of the guide if you haven't already. It tells how to set a udev rule so that RetroArch will see the xboxdrv vitualized keyboard as being a real keyboard.
                            ExarKunIvE 1 Reply Last reply Reply Quote 1
                            • ExarKunIvE
                              @mediamogul
                              the funny thing is that i already had that, so when i looked at it again i saw my problem
                              you have this on your guide
                              SUBSYSTEM=="input", ATTRS{name}=="Microsoft X-Box 360 pad - Keyboard Emulation", GROUP="users", MODE="0666", ENV{ID_INPUT_KEYBOARD}="1"
                              i had to change it to this
                              SUBSYSTEM=="input", ATTRS{name}=="Microsoft X-Box 360 pad", GROUP="users", MODE="0666", ENV{ID_INPUT_KEYBOARD}="1"
                              i know that i dont have a custom name but i remember what the cat /proc/bus/input/devicespulled up when i ran it whit the script going.
                              so i think that did it, but i will have to do more testing tomorrow, but it is looking good now
                              and as always thanks for the help
                                @ExarKunIv said in Guide: Advanced Controller Mappings:
                                you have this on your guide... i had to change it to this
                                I'll test that with a few controllers. It may need to be changed in the guide. Thanks for pointing it out.
                                • ExarKunIvE
                                  ExarKunIv
                                  well i have done testing on my end and my config works, and so do the others even with the change for the 99-xboxdrv.rules
                                  here is my config for 8BitDo to work with videopac/Odyssey2
                                  if [ "$1" = "videopac" ]
                                  then
                                      --silent \
                                  	--force-feedback \
                                  	--mimic-xpad \
                                          --deadzone 15% \
                                  	--evdev-no-grab \
                                  	--dpad-as-button \
                                  	--trigger-as-button \
                                  fi
                                  just remember to do part of section 3A of the guide as @mediamogul says
                                  • ExarKunIvE
                                    @mediamogul
                                    quick question
                                    how do i use this for ports, i mean what do i put in the name
                                    example if i want to set a mapping for rise of the triad, do i use rott for that is the folder name, or does the word port need to be in there due to it being in the port folder?
                                    hope this is clear
                                      @ExarKunIv
                                      $1 is the variable for the system/port name, so:
                                      if [ "$1" = "rott" ]
                                      should do the job.
                                      • ExarKunIvE
                                        @mediamogul
                                        sweet
                                        thanks again
                                        • ExarKunIvE
                                          ExarKunIv
                                          so have been playing round with getting ESC mapped for Solarus. so that way i can exit it easyly.
                                          my mapping works great
                                          if [ "$1" = "zelda_roth_se,zsdx,zsxd" ]
                                          then
                                              --evdev /dev/input/event1 \
                                              --silent \
                                          	--force-feedback \
                                          	--mimic-xpad \
                                                  --deadzone 15% \
                                          	--evdev-no-grab \
                                          	--dpad-as-button \
                                              --ui-buttonmap a=KEY_UNKNOWN,b=KEY_UNKNOWN,start=KEY_UNKNOWN,back=KEY_UNKNOWN,x=KEY_UNKNOWN,y=KEY_UNKNOWN,lt=KEY_UNKNOWN,rt=KEY_UNKNOWN,lb=KEY_UNKNOWN,rb=KEY_UNKNOWN,tl=KEY_UNKNOWN,tr=KEY_ESC \
                                          	--ui-axismap x2=void,Y2=void \
                                          fi
                                          but only if i put it in manually. if will not auto start.
                                          im sure that i have something wrong with the port name
                                          i have tryed just useing Solarus but no go. any ideas?
                                            @ExarKunIv
                                            Try changing:
                                            to:
                                            if [ "$2" = "solarus" ]
