    Guide: Advanced Controller Mappings
    joystickcontrollermappingxboxdrvscummvm
    626 Posts 35 Posters 525.7k Views
    • ExarKunIvE
      ExarKunIv @mediamogul
      @mediamogul
      thanks for getting back to me, but sadly nothing happens
      i ran cat /proc/bus/input/devices and all it pulls up is my 8BitDo.
      this is beginning to bug me
        mediamogul Global Moderator @ExarKunIv
        @ExarKunIv
        It might be:
        if [ "$1" = "solarus" ]
        instead
        • ExarKunIvE
          @mediamogul
          tired that too, still nothing
            @ExarKunIv
            Try putting the following at the top of your runcommand-onstart:
            ## Name of the emulator
            echo $1 >> /dev/shm/runcommand.log
            ## Name of the software used for running the emulation
            echo $2 >> /dev/shm/runcommand.log
            ## Name of the rom
            echo $3 >> /dev/shm/runcommand.log
            ##Executed command line
            echo $4 >> /dev/shm/runcommand.log
            Then, after you launch solarus, look at your /dev/shm/runcommand.log file and list what's on the first four lines.
            • ExarKunIvE
              @mediamogul
              zelda_roth_se
              solarus
              LD_LIBRARY_PATH=/opt/retropie/ports/solarus/lib /opt/retropie/ports/solarus/bin/solarus_run /opt/retropie/ports/solarus/share/solarus/zelda_roth_se/
              /opt/retropie/configs/all/runcommand-onstart.sh: line 109: syntax error near unexpected token `&'
              /opt/retropie/configs/all/runcommand-onstart.sh: line 109: `&'
              Parameters:
              Executing: LD_LIBRARY_PATH=/opt/retropie/ports/solarus/lib /opt/retropie/ports/solarus/bin/solarus_run /opt/retropie/ports/solarus/share/solarus/zelda_roth_se/
              Solarus 1.4.5
              Opening quest '/opt/retropie/ports/solarus/share/solarus/zelda_roth_se/'
              AL lib: (WW) alc_initconfig: Failed to initialize backend "pulse"
              2D acceleration: yes
              ask and you will receive
                @ExarKunIv
                Based on "solarus" being the second line,
                if [ "$2" = "solarus" ]
                should be doing the trick. After you launch solarus with that setting, check to see if xboxdrv is at least launching alongside it from another terminal.
                • ExarKunIvE
                  @mediamogul
                  how do i check if xboxdrv is running.
                  and should i worry about /opt/retropie/configs/all/runcommand-onstart.sh: line 109: syntax error near unexpected token &'
                  /opt/retropie/configs/all/runcommand-onstart.sh: line 109: &'
                    @ExarKunIv
                    You can run top via ssh.
                    and should i worry about... line 109
                    It might be the issue here. If nothing else, it's likely to be some other issue that needs looking at. Take a look at line 109 of the runcommand-onstart.sh closely to see if anything stands out.
                    • ExarKunIvE
                      @mediamogul
                      again thank you for the help.
                      i ran top and xboxdrv is running.
                      so i took a better look at the code. i did not see anything so i deleted
                      fi
                      and copyed it from a code above and it worked. i think i had a enter before
                      fi
                      would not of thought that would of done it, and
                      works great
                        @ExarKunIv
                        Nice catch!
                        works great
                        Good to hear.
                          Chillimonster
                          Been linked to this thread whilst trying to sort Daphne / Dragonrise issues.
                          Looks like this could work.
                          Just need to get my head around how it all works and generate a config file (only 210 posts to read through!)
                          Thanks for the work that has gone into this.
                          • E
                            EVEGames
                            @mediamogul ,
                            This guide is a jem, thank you for creating it and monitoring this thread for the past seven months.
                            Quick question please.
                            I just switched from a wired SNES style pad to a wireless XBox360 controller, and following the instructions on the GutHub RetroPie Setup Wiki for XBox360 controllers, I was lead to believe that XPad is the way to go, due to kernel issues plaguing XBoxdrv. But I see that this thread still has people using XBoxdrv, and clearly XBoxdrv is vastly more configurable than XPad. So my question, before fully diving into this guide and applying it, is, are the warnings against using XBoxdrv unfounded? Let me put it another way, is there a single specific pitfall to avoid which would render XBoxdrv problematic? If it's about the kernel, any hints on how to determine what version of the kernel I am currently on, and how to avoid updating it in the future would be a big help. If the answer to these questions is available in the pages of this thread, please let me know that and I'll search it out.
                            Thanks!
                            -Dave
                              Chillimonster
                              To save me a lot of reading can someone give me a set of simplified steps to implement this for daphne and my dragonrise zero delay encoder, or even the most relevant posts to read
                              There is a lot of stuff in here that i'm not too sure of and dont want to mess my system up (Have taken a backup just in case!)
                                mediamogul Global Moderator @EVEGames
                                @EVEGames
                                xboxdrv has two different modes of operation. The first acts as a tailored driver for an XBox 360 controller. It's here where there are kernel issues and if the goal is to simply get an XBox 360 controller up and running, then XPad is recommended. However, xboxdrv can also act as a mapping soltion for any controller that reports itself as a joystick event to the system, which also happens to apply to an XBox 360 controller. Using it in this way presents no kernel conflicts to my knowledge.
                                @Chillimonster
                                While the information is currently unfamiliar to you and seems like a lot to digest, don't let it put you off too badly. Most of the length of the guide is dedicated to detailing the minor steps that are sometimes taken for granted. Make no mistake, this is more of an advanced technique than just normally configuring your controller, but by documenting every button press and keystroke along the way, you might be surprised at how quickly it moves from top to bottom once begun.
                                When I replied to you earlier, I took a brief look at the dragonrise zero delay encoder and what I found seemed to indicate that it identifies itself as a joystick event, which would allow it to work here. However, some encoders identify as a keyboard and cannot be mapped by xboxdrv. Fortunately, if you decide to move forward with this, you'll know in the earliest steps of the guide whether this will ultimately be possible when running evtest. If your button presses come back as BTN_ you can continue on. If they come back KEY_ then unfortunately it's not going to work, but at least you won't have wasted much time on anything.
                                C E 2 Replies Last reply Reply Quote 1
                                  Chillimonster @mediamogul
                                  @mediamogul
                                  Many thanks for the clarification on the DR encoders.
                                  Will have a play later and report back (as no doubt a config file will be of use to others if i get it working)
                                  Chris
                                    mediamogul Global Moderator @Chillimonster
                                    @Chillimonster
                                    a s no doubt a config file will be of use to others if i get it working
                                    Very much so.
                                      Chillimonster
                                      When i run evtest i get continuous scrolling of various text.
                                      Is there any way to stop it to get the details i need?
                                        @Chillimonster
                                        Someone else recently reported the same issue with the scrolling data. Is there anyway you can report back as to exactly what information is scrolling? Does it make mention of an axis repeatedly by chance?
                                        • E
                                          EVEGames @mediamogul
                                          @mediamogul said in Guide: Advanced Controller Mappings:
                                          ...xboxdrv can also act as a mapping soltion for any controller that reports itself as a joystick event to the system, which also happens to apply to an XBox 360 controller. Using it in this way presents no kernel conflicts to my knowledge.
                                          That said, @mediamogul, if I follow your guide, am I operating the driver purely in 'mapping solution' mode by default? Also should I uninstall my Xpad driver before attempting your guide? Many thanks for the help.
                                            @mediamogul
                                            OK by following the guide and in particular post 126 on this thread i have mapped the dragonrise to use xboxdrv when booting daphne.
                                            Now the next issue.
                                            Daphne (The emulator i am having problems with) always looks for the first js0, and the mapped xboxdrv is js1
                                            is there a way to have this appear as js0 for this emulator?
