    Guide: Advanced Controller Mappings
    joystickcontrollermappingxboxdrvscummvm
    626 Posts 35 Posters 522.7k Views
      mediamogul Global Moderator @pjft
      @pjft said in Guide: Advanced Controller Mappings:
      I was wondering if anyone would already have such mappings of PS3-controller-to-keyboard for these games
      I've never seen anyone discussing those particular games, but somewhere in this thread, there's a guy who mapped his PS3 controller and detailed it. You could knock off a few steps by cannibalizing his command and just add in the keys you want. It's probably best to start from scratch so that all the steps are accountable, but even then, it could still be used as a good reference.
        pjft @mediamogul
        @mediamogul thanks. I'll probably do it from scratch then, just need to find the time :)
        I'll post any updates and likely all the questions when I run into difficulties.
          dudleydes @pjft
          @pjft You can find an xboxdrv config here that I use to map my PS3 controller in ROTT, a source port of Rise of the Triad.
          It differs slightly from the PS3 controller example given in the xboxdrv repo. In my case, the PS button, or guide in xboxdrv, is mapped to KEY_#704 whereas in the xboxdrv example, it's mapped to KEY_#720. My controller is model number CECHZC1E, one of the original SIXAXIS controllers. If you have a newer model, then KEY_#720 may be the correct mapping.
            spud11 @mediamogul
            @mediamogul Thanks. I've added the code to the runcommand-onstart.sh but it had no effect. A copy of the runcommand.log appears below:
            /opt/retropie/configs/all/runcommand-onstart.sh: line 2: $'\r': command not found
            /opt/retropie/configs/all/runcommand-onstart.sh: line 18: syntax error near unexpected token `&'
            /opt/retropie/configs/all/runcommand-onstart.sh: line 18: `&
            Parameters:
            Executing: pushd /opt/retropie/emulators/uae4arm/; ./uae4arm -config="/home/pi/RetroPie/roms/amiga/Alien Breed Special Edition '92.uae"
            /opt/retropie/emulators/uae4arm /opt/retropie/supplementary/runcommand
            Amiberry build 2017-01-08, by Dimitris (MiDWaN) Panokostas and Olly Aigner
            Based on previous work by Chips and TomB (Pandora)
            Joystick 0 : DragonRise Inc.   Generic   USB  Joystick
                Buttons: 12 Axis: 4 Hats: 1
            Joystick 1 : DragonRise Inc.   Generic   USB  Joystick
            Joystick 2 : DragonRise Inc.   Generic   USB  Joystick
            Joystick 3 : DragonRise Inc.   Generic   USB  Joystick
            starting sound thread..
            stopping sound thread..
            xboxdrv: no process found
              mediamogul Global Moderator @spud11
              @spud11
              Line 2 & 18 seem to be the problem. Making sure that runcommand-onstart.shis still identical to that last time you launched it, post it's contents and let's have a look.
                spud11 @mediamogul
                @mediamogul Thanks for your quick reply. Here it is:
                #!/bin/sh
                if [ "$1" = "amiga" ]
                then
                    --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.2.3:1.0-event-joystick \
                	--silent \
                	--detach-kernel-driver \
                	--force-feedback \
                	--deadzone-trigger 15% \
                	--deadzone 4000 \
                	--trigger-as-button \
                	--mimic-xpad \
                	--device-name "Amiga Joystick Player 1 (xboxdrv)" \
                	--evdev-absmap ABS_X=y1,ABS_Y=x1 \
                	--evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start \
                	--ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void \
                fi
                Line 2 is the blank line and line 18 is the &. I'm using Notepad ++ which gives line numbers so it is clear.
                  @spud11
                  Line 2 is the blank
                  In a shell script, the first line is reserved for #!/bin/sh, making the second line count as the first and so on. That said, the errors you're getting still aren't jibing with the command given. The only thing I can think of is that Notepad++ may be formatting things unexpectedly. In the command line try:
                  nano /opt/retropie/configs/all/runcommand-onstart.sh
                  From there, look to see if anything is out of place in line 2 & 18 by comparison. If it is, you'll either want to use another text editing program or see if notepad++ can support 'UNICODE UTF-8' through a setting.
                    Chillimonster @spud11
                    @spud11
                    Thanks for checking, i really appreciate it.
                    I need to dedicate some time to looking at emulating keyboard input for daphne, as i think that is going to be the answer.
                    Chris
                      spud11 @Chillimonster
                      @Chillimonster That's no problem at all. I think you're right - it's likely to be the keys that wind up making the difference. I reckon it'll be more than a week before I start testing Daphne (you've sparked my interest again in getting it working), so if you do get it working, could you please post your config here?
                        spud11 @mediamogul
                        @mediamogul said in Guide: Advanced Controller Mappings:
                        Hi mediamogul.
                        I've now checked Notepad++ and it is using Unicode UTF-8. I've looked at the code using nano too and removed line 27 which was blank. There doesn't appear to be anything else that stands out. The code appears to be correct and I've tested again and it doesn't work.
                        Given that line 2 is actually line 1, the error $'\r' looks like it relates to "$1" - that is, it can't find or identify the "amiga" system for whatever reason.
                        I can't help but feel it's got something to do with my amiga setup which has individual .uae configs for each game (as per the Amiga wiki but using hard drives for each game, not floppy disks), but could be wrong.
                        I've previously tried some of the other $ commands. Maybe that is the way to go?
                        Or I wonder if there might be some other file that I've changed that is affecting things. I recall somewhere reading that there was another file that might require changing and I made that change. Can't find what it was now.
                        Or maybe one way to test things is just to replace "amiga" with another random system and see if it works for other systems. That would at least rule out that there is an inherent problem with the code.
                          @spud11
                          That very well could be. Launch another game the way you have been, then post the contents of /dev/shmruncommand.info.
                            spud11 @mediamogul
                            @mediamogul
                            Okay, thanks. I tried another Amiga game with the same outcome, and once again it doesn't like the& (or & and fi) at the end:
                            Parameters:
                            Executing: pushd /opt/retropie/emulators/uae4arm/; ./uae4arm -config="/home/pi/RetroPie/roms/amiga/Alien Drug Lords.uae"
                            Also, I found the other change to which I have referred in my previous comment which I made after following the guide:
                            sudo nano /etc/udev/rules.d/99-xboxdrv.rules
                            SUBSYSTEM=="input", ATTRS{name}=="Microsoft X-Box 360 pad - Keyboard Emulation", GROUP="users", MODE="0666", ENV{ID_INPUT_KEYBOARD}="1"
                              @spud11
                              I actually need to see the contents of /dev/shm/runcommand.info. Make sure of course that you have just previously launched a game.
                                spud11 @mediamogul
                                @mediamogul Oh, sorry. I missed that it was the info file, not the log file, you wanted to see. Will send after I get home from work. Thanks.
                                  @spud11
                                  Not a problem.
                                    @spud11
                                    Of course i will.
                                    I'll try and get some time on it over weekend and update the thread accordingly
                                      spud11 @mediamogul
                                      @mediamogul Sorry about the delay. Wound up not getting home to very late. Here is the runcommand.info file:
                                      amiga
                                      uae4arm
                                      Does this correspond to the "$" inputs 1, 2, 3, 4?
                                        @Chillimonster Thanks!
                                          @spud11 said in Guide: Advanced Controller Mappings:
                                          It does and I was hoping to see something wrong here that would explain your issues, but everything seems to be in order. I won't lie, I'm starting to run out of ideas here myself. One thing you can try is to add:
                                          #!/bin/bash
                                          	--silent \
                                          	--force-feedback \
                                          	--deadzone 4000 \
                                          	--mimic-xpad \
                                          to it's own separate script and in turn launch it from runcommand-onstart.sh with:
                                          then
                                          sh /path/to/new/script.sh
                                          fi
                                          • E
                                            EctoOne
                                            Sorry to interrupt, I didn't read all of the lasts post. It is about setting up xboxdrv to work with uae4arm and the possibility that launching uae files might cause some trouble right? If so, I have no problems with the same setup. Although I replaced uae4arm with amiberry. So if needed I could copy the controller setup part from the guide I used.
                                            The only thing that I can't figure out, is how to get custom controls within uae4arm/amiberry to work. Which would be great if I could map the X, Y Buttons to whatever the game needs. But from what I've found that seems to be a bug with amiberry (never tried it with uae4arm), so I have to wait for an update to that.
                                            mediamogulM S 2 Replies Last reply Reply Quote 0
