    Guide: Advanced Controller Mappings
    joystickcontrollermappingxboxdrvscummvm
    626 Posts 35 Posters 513.4k Views
      mediamogul Global Moderator @EctoOne
      @EctoOne said in Guide: Advanced Controller Mappings:
      If so, I have no problems with the same setup.
      On paper, there should be nothing preventing this from working on any setup. There has to be some other factor at play that is not being accounted for, but I'll be hornschwaggled if I can see it.
      Which would be great if I could map the X, Y Buttons to whatever the game needs.
      Almost any computer game responds to keyboard input. You could always map the keys to the controller.
      • E
        EctoOne @mediamogul
        @mediamogul said in Guide: Advanced Controller Mappings:
        Yes I know that. It works for something like ScummVM where you can map the start button to F5. Because that's the key most ScummVM games use to access the menu. But for Amiga games it's more different what keys are needed. Example I want to use X as Spacebar for Turrican but on The Clue! I want X to be F1 to be able to open the menu.
        Uae4arm has a menu to map buttons on its own but I can't get it to work. And I don't know if that's an uae4arm/amiberry problem or if there is a conflict with my setup.
          @EctoOne
          Ah, I gotchya. I have a similar need for some individual system games. If you use if [ "$3" = "/path/to/rom" ] in your if/else statement, you can launch your mappings based on individual ROMs rather than have them applied to whole systems.
            spud11 @mediamogul
            @mediamogul I've now given that one a go too:
            #!/bin/sh
            if [ "$1" = "amiga" ]
            then
            sh /opt/retropie/configs/amiga/joystick.sh
            fi
            joystick.sh is:
            #!/bin/sh
                --evdev /dev/input/by-path/platform-3f980000.usb-usb-0:1.2.3:1.0-event-joystick \
            	--silent \
            	--detach-kernel-driver \
            	--force-feedback \
            	--deadzone-trigger 15% \
            	--deadzone 4000 \
            	--trigger-as-button \
            	--mimic-xpad \
            	--device-name "Amiga Joystick Player 1 (xboxdrv)" \
            	--evdev-absmap ABS_X=y1,ABS_Y=x1 \
            	--evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start \
            	--ui-buttonmap lb=void,rb=void,tl=void,tr=void,guide=void,lt=void,rt=void \
            Unfortunately, there is no output .log file .info file.
            It seems that the runcommand-onstart.sh will work, but only if there is no if/then statement.
            I'll have a quick go at replacing "amiga" with another system and see what eventuates.
              spud11 @spud11
              @spud11 Tried with "c64" instead of "amiga" and same results as for amiga - separate script no output in dev/shm and a similar output if the sudo statement appears directly in the runcommand statement.
              Perhaps I could somehow include reference to the script in the .uae files instead? I don't know.
                spud11 @EctoOne
                @EctoOne You seem to have a similar problem to me. I'm using amiberry too. Although the author thought he had got custom controls to work from the f12 menu, I haven't been able to get that working either. Apparently, he is thinking of "going" libretro, but it hasn't happened yet.
                What I do know is that if I use runcommand-onstart.sh to install xboxdrv (but without the if/then statement), my "amiga joystick" does appear in the uae4arm menu (ie press f12) and I can select that joystick and all works well in game after "resuming" the game.
                Also, it is possible to manually bulk change all the individual game .uae scripts to default to the "amiga joystick" for player 1. I use a Windows program called "Find and Replace " to achieve that: http://findandreplace.sourceforge.net
                That will work, but obviously because there is no if/then statement in runcommand-onstart.sh, my controls are all screwed up for every other emulator/core which is self-defeating.
                • E
                  EctoOne @mediamogul
                  @EctoOne
                  Oh really, that sounds like a solution but it also sounds like a lot more work. If the custom controls within uae4arm where working, i could map the buttons on the fly and to see what's best and then simply save the config file. But thanks for the hint, i might give it a shot.
                  @spud11
                  This is a copy of the guide i used (Can't provide a link, because it also contains games)
                  And this is my runcommand-onstart.sh (scummvm settings removed to avoid confusion):
                  #!/bin/sh
                  ## Uncomment one or all of the following if you need to find some information about the emulator or roms
                  ## Name of the emulator
                  #echo $1 >> /dev/shm/runcommand.log
                  ## Name of the software used for running the emulation
                  #echo $2 >> /dev/shm/runcommand.log
                  ## Name of the rom
                  #echo $3 >> /dev/shm/runcommand.log
                  ##Executed command line
                  #echo $4 >> /dev/shm/runcommand.log
                  ### The FUN begins
                  #Get ROM name striping full path
                  rom="${3##*/}"
                  ### Set variables for your joypad and emulator
                  ### Basic Configuraions - Standard controller mappings
                  LogiF710="/opt/retropie/supplementary/xboxdrv/bin/xboxdrv > /dev/null \
                  	--evdev /dev/input/event3 \
                  	--silent \
                  	--deadzone=4000 \
                  	--force-feedback \
                  	--mimic-xpad \
                  	--evdev-absmap ABS_X=x1,ABS_Y=y1,ABS_RX=x2,ABS_RY=y2,ABS_HAT0X=dpad_x,ABS_HAT0Y=dpad_y \
                  	--evdev-keymap BTN_SOUTH=a,BTN_EAST=b,BTN_NORTH=x,BTN_WEST=y,BTN_TL=lb,BTN_TR=rb,BTN_TL2=lt,BTN_TR2=rt,BTN_THUMBL=tl,BTN_THUMBR=tr,BTN_SELECT=back,BTN_START=start,BTN_MODE=guide \
                  	--calibration x1=-32767:0:32767,y1=-32767:0:32767,x2=-32767:0:32767,y2=-32767:0:32767"
                  ### Extended Configurations
                  ### Specific emulator configuration or any other parameters you will need only for some emulators
                  amiga="--axismap -Y1=Y1,-Y2=Y2 \
                  	--buttonmap tl^toggle=tl \
                          --buttonmap rt^toggle=rt \
                  	--ui-axismap tl+x1=REL_X:5,tl+y1=REL_Y:5 \
                  	--ui-buttonmap tl+a=BTN_LEFT,tl+b=BTN_RIGHT \
                  	--ui-buttonmap start=KEY_P,back=void \
                  	--ui-buttonmap rt+a=KEY_ENTER,rt+b=KEY_ESC,rt+x=KEY_SPACE,rt+y=KEY_F1,rt+du=KEY_UP,rt+dd=KEY_DOWN,rt+dl=KEY_LEFT,rt+dr=KEY_RIGHT \
                  	--ui-buttonmap guide=KEY_F12,guide+start=KEY_Q \
                  	--ui-axismap x2=void"
                  fourway="--four-way-restrictor"
                  invert="--ui-buttonmap du=KEY_DOWN,dd=KEY_UP"
                  ### Kill Command
                  xboxkill="sudo killall >/dev/null xboxdrv"
                  ### Execute the driver with the configuration you need
                  # $1 is the name of the emulation, not the name of the software used
                  # it is intellivision not jzintv
                  case $1 in
                      amiga)
                          $xboxkill
                          joycommand="$LogiF710 $amiga &"
                          eval $joycommand
                  esac
                  Beware that i'm using a Logitech F710 controller, so you can't probably just copy paste that. This mapping toggles mouse/joystick function when pressing the left analog stick and also toggles cursor keys on the digipad when pressing RT/R2 (instead of holding RT/R2)
                    mediamogul Global Moderator @spud11
                    @spud11
                    I'm curious as to whether or not any if/then statements will run on your setup. Try adding the test below to your runcommand-onstart.sh and then look to see if the two test sentences were written in runcommand.log after running a game.
                    test=yes
                    if [ "$test" = "yes" ]
                    then
                    echo "This is only a test." >> /dev/shm/runcommand.log
                    fi
                    then
                    echo "This is also only a test." >> /dev/shm/runcommand.log
                    fi
                      spud11 @mediamogul
                      @mediamogul The runcommand-onstart.sh looks like this:
                      #!/bin/sh
                      then
                      	--silent \
                      	--force-feedback \
                      	--deadzone 4000 \
                      	--mimic-xpad \
                      fi
                      test=yes
                      then
                      fi
                      then
                      fi
                      And the runcommand.log is this:
                      /opt/retropie/configs/all/runcommand-onstart.sh: line 2: $'\r': command not found
                      /opt/retropie/configs/all/runcommand-onstart.sh: line 18: syntax error near unexpected token `&'
                      /opt/retropie/configs/all/runcommand-onstart.sh: line 18: `&
                      Parameters:
                      Executing: pushd /opt/retropie/emulators/uae4arm/; ./uae4arm -config="/home/pi/RetroPie/roms/amiga/Alien Breed Special Edition '92.uae"
                      /opt/retropie/emulators/uae4arm /opt/retropie/supplementary/runcommand
                      Amiberry build 2017-01-08, by Dimitris (MiDWaN) Panokostas and Olly Aigner
                      Based on previous work by Chips and TomB (Pandora)
                      Joystick 0 : DragonRise Inc.   Generic   USB  Joystick
                          Buttons: 12 Axis: 4 Hats: 1
                      Joystick 1 : DragonRise Inc.   Generic   USB  Joystick
                      Joystick 2 : DragonRise Inc.   Generic   USB  Joystick
                      Joystick 3 : DragonRise Inc.   Generic   USB  Joystick
                      starting sound thread..
                      stopping sound thread..
                      xboxdrv: no process found
                        spud11 @EctoOne
                        @EctoOne Hi EctoOne. I've seen a guide similar to the one you've provided. Thanks for that. I think most of the characteristics in the guide I've got, but will look at more closely.
                        Also, I'm familiar with your runcommand-onstart.sh. I recall the script it's based on had a "per rom" setting (as mediamogul has pointed out) as a possible way of getting xboxdrv working. (It was for mame games, and I think you've got a residual "per rom" setting from the original script in your script - rom="${3##*/}" too).
                        I agree "per rom" would be a lot of work unless it could be automated in some way, but that does assume we're able to get xboxdrv with "if/then" working at all with the amiga. At this stage, it doesn't appear that the if/then statement works at all, for whatever reason, as mine at least "hangs" straight away on the first line being the "if" statement $'\r'.
                        mediamogulM E 2 Replies Last reply Reply Quote 0
                          @spud11
                          I'm somewhat stumped. I'll continue to give it thought, but I really can't see a reason why this isn't working. The fact that you're getting script errors regarding information that is not even in your script is really odd. You might try looking around for other instances online where similar statements are read incorrectly and what might cause such a thing.
                          • E
                            EctoOne @spud11
                            @spud11
                            I'm not sure what the rom thing is about in my script. I just copied it, entered the F710 buttons and made some changes to the mapping.
                            But I noticed that in my script are no if/fi parts compared to yours. Maybe you should go and try mine.
                              spud11 @mediamogul
                              @mediamogul Will do. Thanks.
                                spud11 @spud11
                                @spud11 Thanks, EctoOne. I will have a go with your script too and I'll let you know. Thanks.
                                  spud11 @EctoOne
                                  @EctoOne Hi. I adapted your script as below which I think should work:
                                  #!/bin/sh
                                  ## Name of the rom
                                  ### The FUN begins
                                  rom="${3##*/}"
                                  DragonRise="/opt/retropie/supplementary/xboxdrv/bin/xboxdrv
                                  	--silent \
                                  	--deadzone=4000 \
                                  	--force-feedback \
                                  	--mimic-xpad \
                                  amiga="--device-name "Amiga Joystick Player 1 (xboxdrv)" \
                                  	--evdev-keymap BTN_TRIGGER=x,BTN_THUMB=y,BTN_THUMB2=a,BTN_PINKIE=b,BTN_BASE3=back,BTN_BASE6=start \"
                                  ### Kill Command
                                  xboxkill="sudo killall xboxdrv"
                                  case $1 in
                                      amiga)
                                          $xboxkill
                                          joycommand="$DragonRise $amiga &"
                                          eval $joycommand
                                  esac
                                  I ended up with the following output:
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 5: $'\r': command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 8: $'\r': command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 11: $'\r': command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 14: $'\r': command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 15: $'\r': command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 19: $'\r': command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 36: Amiga Joystick Player 1 (xboxdrv): command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 37: --evdev-absmap: command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 38: --evdev-keymap: command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 39: $'\r': command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 41: $'\r': command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 42: $'\r': command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 45: $'\r': command not found
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 49: syntax error near unexpected token `$'in\r''
                                  /opt/retropie/configs/all/runcommand-onstart.sh: line 49: `case $1 in
                                  Parameters:
                                  Executing: pushd /opt/retropie/emulators/uae4arm/; ./uae4arm -config="/home/pi/RetroPie/roms/amiga/Alien Breed Tower Assault.uae"
                                  I'll trawl the forums and see if I can find any information about the error $'\r'. Thanks.
                                  I'll probably need to think of options other than using runcommand-onstart. Possibly even recompiling the emulator itself.
                                  • E
                                    EctoOne @spud11
                                    @spud11
                                    I'm no tech expert but seeing you getting even more errors with my script let's me think that either your xboxdrv version is different or something went wrong during the installation.
                                    Edit: From what I've found is that \r seems to be caused by Windows newline characters. You said that you're using Notepad++ so that would make sense if you copy/pasted my script. So you should try to ssh into your Pi with putty. Use nano to edit the file (mentioned above by @mediamogul), delete everything, and copy it back in using middle mouse button. Or delete the file and make a new one with nano.
                                    S 2 Replies Last reply Reply Quote 1
                                      spud11 @EctoOne
                                      @EctoOne Thanks for that tip. I'll try that later.
                                      That might explain why earlier on, I was finding that the xboxdrv script was working 100% in rc.local only when the whole script was on one line, but didn't seem to work when I had used \ and enter at the end of each line.
                                      I'll try the copy/paste way with nano first and then, if that doesn't work, I'll manually type it all back in with nano. A bit laborious but best way to ensure the script works.
                                      Just checked the WinSCP documentation too:
                                      "Text/ASCII Transfer Mode
                                      For this reason, file transfer clients and servers support a text/ASCII transfer mode.
                                      When transferring a file in this mode, the file gets (ideally) converted from a format native to a source system, to a format native to a target system.
                                      For example, when uploading a text file using text mode from Windows to Unix system, the file line endings get converted from CR+LF to LF.
                                      Opposite to the text/ASCII transfer mode is a binary transfer mode that transfer the file as is (binary identical).
                                      WinSCP by default uses the binary transfer mode for all regular file transfers. "
                                      I've also at various times copied the runcommand-onstart.sh from Windows to the Pi and made the file executable, so based on the above, the transfer is likely to have been in binary transfer mode by default, meaning that /r new line errors are very possible.
                                        spud11 @EctoOne
                                        @EctoOne @mediamogul
                                        You, Sirs, are Gods! Thank you to you both for your patience and help. EctoOne, you were ultimately correct. It had to do with the "newline" issue as between Windows and Unix.
                                        To help anyone else with a similar issue, what I did was, via Putty, I deleted the old runcommand-onstart.sh and created a new one and made it executable. Then I typed:
                                        sudo nano /opt/retropie/configs/all/runcommand-onstart.sh
                                        and manually typed in the whole code with the if/then statement:
                                        #!/bin/sh
                                        then
                                        --silent \
                                        --force-feedback \
                                        --deadzone 4000 \
                                        --mimic-xpad \
                                        --evdev-keymap BTN_TRIGGER=X,BTN_THUMB=Y,BTN_THUMB2=A,BTN_PINKIE=B,BTN_BASE3=BACK,BTN_BASE6=START \
                                        fi
                                        Xboxdrv now works as it should with the uae4arm emulator. I have a runcommand-onend.sh file as well which terminates xboxdrv automatically.
                                        I have now altered the default settings in WinSCP from "binary" to "text", but decided that, from a pure troubleshooting perspective, it would just be easier to manually enter the details with putty, rather than copy and paste from another file or use WinSCP to transfer the file or edit.
                                        Also, there is one other thing. I've got samba shares operating as well in Windows and regularly transferred files including the runcommand-onstart.sh (which I'd sometimes created in Windows with Notepad++ during this troubleshooting process) from Windows to the raspberry pi. I'm sure that would also have led to the "newline" issue too.
                                        Sometimes it's just better to use the raspberry pi's native editors, I suppose. Thanks, guys.
                                        mediamogulM 1 Reply Last reply Reply Quote 3
                                          @spud11
                                          Glad to see you got it going.
                                          • H
                                            Hubz
                                            Hey quick question, is it possible to map 2 controllers with Xboxdrv for two players to be able to play? It might have been discussed in the thread but I didn't find it. I found mappings for the 2nd player though so I'm assuming it's possible just wasn't sure how to pull it off.
