    Pi in a Dreamcast VMU Build - WIP
    buildprojecthandheldvmudreamcast
    157 Posts 7 Posters 102.4k Views
      Thanks to @celly I now have some really nice white VMUs coming my way.
      The plan now is to figure out how to do this with one of the blue ones, then do it "for real' with a white one.
      mooseprM 1 Reply Last reply Reply Quote 0
      • mooseprM
        moosepr @obsidianspider
        @obsidianspider the white ones do have the Best look! I don't have the flair/time/patience for case modding though. Still have a GBA shell stripped and ready for the slaughter
        want to get a tft into your project, look no further than here https://retropie.org.uk/forum/topic/7464/ili9341-tft-screen-guide
          ABrugsch
          So i got the big parts stripped off that charge board, replaced the big inductor with a more expensive, flatter wurth one. Since i was doing other stuff as well at the hackspace tonight (making up some DMG bivert boards) I didn't manage any testing :(
          Someone also sprung a free DS and DSi on me... :D
          Along with some really legit looking bootleg GBA pokemon carts.
          • mooseprM
            moosepr
            i was messing in my parts bin and found a few of these
            http://www.ebay.co.uk/itm/371440045594
            the pcb at the end is actually really small. couldnt pry it out of the plastic while i was looking, but desolder the battery terminals and the usb socket, and it looks to be quite tiny!!
              ABrugsch @moosepr
              @moosepr I think my board is actually meant for something just like that. this was linked at the bottom of that item:
              http://www.ebay.co.uk/itm/2600mAh-Battery-USB-Case-Kit-HOT-Bank-18650-DIY-Power-Box-For-All-Phone-Charger/291950546291
                ABrugsch
                here's the reduced size charge/boost board:
                removed the USB socket and flashlight switch, swapped the tall inductor for a flat Wurth one
                • mooseprM
                  moosepr
                  @ABrugsch whats this? a boost board for ants?
                  what does the button on there actually do?
                    ABrugsch @moosepr
                    @moosepr as far as i can tell, the switch JUST activates the flashlight LED (the big through hole one) so it's coming off. if it does anything else, I can always wire on a remote one. there are 2 0402 SMD LED's underneath it for status (so far just flash alternating red and blue with no battery attached)
                      obsidianspider @ABrugsch
                      @ABrugsch When you remove a component that has through hole and surface mount parts to it, like that USB port, how do you go about it? Things like that kick my butt every time and I end up making a huge mess.
                      How did you go about replacing the inductor? It looks like all of the contacts are underneath it.
                        ABrugsch @obsidianspider
                        @obsidianspider it was a bit of a bitch tbh... The tall Inductor was in the way of the usb so that had to come off first... Bit of hot air, but not too much because of the surrounding stuff, bit of light prising with the hot iron but again not too much that the opposite pad doesn't lift. And just go back and forth til is comes off. Then the usb port i got lucky with as one side wasn't too well soldered and some wick got most of the through hole part. Then more flux and wick for the surface mount legs with some gentle prising with heavy tweezers.
                        This was pretty next level desoldering really! But then I'm a soldering ninja ;)
                          @ABrugsch If you've seen my cut down Pi 3, you'll notice that I am definitely not a ninja, but I'm working on it.
                            @obsidianspider said in Pi in a Dreamcast VMU Build - WIP:
                            It's not too bad really. Those ribbon sockets are super tricky to get off cleanly. My very first attempt at an A+ looks much worse than that... I'll get a pic...
                            Edit: check this https://www.hackster.io/abrugsch/mameboypi-ff2428
                              My blue VMUs arrived today. Brand new, perfect shape, and yeah, small. I know I read the dimensions on the Internet, but seeing one in person is different. I hadn't seen a VMU in real life in at least ten years, and wow, this is going to be interesting. Screens are still on their way over from China, but I can work on finding test points for the buttons and hope that there's some common grounding going on.
                              mooseprM 1 Reply Last reply Reply Quote 1
                              • mooseprM
                                @obsidianspider I have that problem all the time! Design a PCB, see the components all zoomed in, think nothing of if, then I see those smd components arrive in the post, and I need a microscope!
                                  obsidianspider @moosepr
                                  @moosepr At this point it's more of a sense of "how the heck am I going to do this?"
                                  I look at my Burger King toy and that thing looks absolutely massive by comparison.
                                  • mooseprM
                                    @obsidianspider that's what she said :|
                                      ABrugsch
                                      some helpful info @obsidianspider : the zero fits exactly between the screw posts :) perhaps some shaving required, but literally scrapings.
                                      the main pcb has screw mountings right next to the button pads so ideal for cutting down. I haven't tested for common ground etc but i don't think it'll be a problem with 4 buttons and 4 directions.
                                      The 1.44 128x128's take up less internal space than the original mono LCD, especially once you remove the carrier PCB.
                                      if you line up the uSD card to be at the bottom, you can cut out the lanyard post and surround and have a perfectly lined up hole for uSD access.
                                        @ABrugsch Thanks for the tips! I have a bunch going on this weekend, but if I get time to take a VMU apart, I'll be sure to post up what I find regarding test pads, etc.
                                          ABrugsch
                                          I'll be playing on tuesday night (my hackerspace night) assuming I'm not spending the whole time desoldering DS lite Slot-2 cartridge ports! (I'm doing a roaring rade in them now...!)
                                          and that the whole space isn't in disarray because of a large storage project going on.
                                            I took apart one of the VMUs on my lunch break today. I took a load of pictures, but this teardown at iFixit does a really good job of explaining things, so I won't reinvent the wheel here.
                                            I wanted to see if I could use the tiny speaker from the VMU right off the Pi's GPIO, so I tried using the Adafruit Pi Zero PWM Audio guide to enable PWM. Since I'll be using Retrogame, I just used the image that I had already set up for my Burger King build. Unfortunately I got crazy boot errors.
                                            Since I was really just trying to see if PWM worked, I put a fresh image on the SD card, set the dtoverlay, and then, well, no sound.
                                            I knew these speakers are tiny, and generally low quality, so I decided to see if the GPIO just wasn't powerful enough. I wired it up to the amp that's powering the speaker on my GBA build, and even with things cranked up, it was really quiet. The VMU speaker is effectively out.
                                            If can't get sound to work on this tiny thing, it won't break my heart, but once parts show up, I'll see if I can cram a tiny Adafruit I2S amp and speaker in the case along with everything else.
